Fog light switch
lilsprout
Fog light switch
Post by lilsprout »
I've got a 92 wagon and I was wondering if there was a factory switch for foglights that would mount on the right side of the instrument panel? I have installed a switch already but I would prefer the look of a factory one.....anybody know?
MPtyza
Post by MPtyza »
There was a foglight switch that would fit in the panel on the lower portion of the left side of the dash. However, if you do not have the air suspension, and can get ahold of the trim piece that holds the height adjustment switch, you could use the foglight switch in that panel just to the right of the steering wheel.
Hocrest
Post by Hocrest »
I have a switch you can buy. I think I even have the plug and a few inches of the wiring harness. It all yours for $5.
[size=75]-97 Legacy (ain't never gonna die)
-92 SVX (attention whore)
-86 Brat (more fun than the SVX)
-92 SVX Racer (lightest SVX)[/size]
lilsprout
Post by lilsprout »
Sounds great Dave.........can you send me a pic......email me...
Thanks,
michael
smh0101
Post by smh0101 »
I also may have the part # for the switch, panel, and blank that fits where the stupid little in-dash-pocket is that is from a 91... It is black to...
dscoobydoo
Post by dscoobydoo »
I posted the part numbers awhile back.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
lilsprout
Post by lilsprout »
I really want to have the switch mounted to the right of the column where that little blank is already...I use the pocket on the lower left for my cell phone....
Post by SubaruNation »
Hocrest wrote:I have a switch you can buy. I think I even have the plug and a few inches of the wiring harness. It all yours for $5.
weird, i paid $15 for it.
thanks alot...
did you get your fog lights wired using the switch?
lilsprout
Post by lilsprout »
not yet....still waiting for the switch to arrive....
what kind of fogs are you wiring up?
the jdm ones?
or does it matter even... :?
i just want to know how to wire them up using the switch i got from hocrest.
lilsprout
Post by lilsprout »
I have already wired in my fogs. Older bosch set. I am currently using the bosch switch...3 wires. I just want to have a more factory looking switch in the dash. Thats why I want the diagram. I will probably just have use a multi meter to figure out whats what but a diagram would save time. I also have a set of bosch driving lights which i've installed with the same kind of switch but in a different location.....lower down. I leave that switch on all the time for high beams so I will leave that one.
dscoobydoo
My suggestion would be to get a loom from a JY car with about 3-4 inches.
Then multi meter off the CC switch for the light indicator part.
The other three wires will be from the power and out to a ground and out to the relay.
It's really not hard to wire up.
The only issue is that I think subaru uses a switched ground not a switched power.
05 GD-STI
00- GF
