94 Legacy Turbo vs 95 Impreza transmissionspecs(AWD manual)
I cant seem to find th specs on the 94 legacy trans. Im looking for a replacement for my 95 Impreza.
I can find info on the 94 legacy NA trans, is the turbo different?
Is the rear diff on the turbo a LSD?
Ratios?
Input shaft?
Halfshafts?
Sensors?
Ratios?
Input shaft?
Halfshafts?
Sensors?
Oh and only the 91s possibly had an lsd unless it was swaped in afterwards as many here have done.
Oh and FYI if you switch to a hydraulic setup you should be able to use WRX clutches and flywheels...
To the left of the brake booster.
