So, Ive been thinking Wankel....
Kelly
Post by Kelly »
Well I guess well see!
Im not gonna start another project until my current one is finished and I get all my debts taken care of. Im prolly thinking springtime, and gettin my GF into autocrossing with it.
206er
Post by 206er »
if you guys think port tuning on rotaries is cool, do some reading about 2 stroke porting. :shock:
BXSS
Post by BXSS »
Funny you mention that, because I recently ported a spare motor for my Zuma scooter. I have to put it on & try it out to see if I killed the cyl., or made power.
The Starlet we run is a Peripherally Ported 12a turbo running on a Holley carb, with a fully programable (32x32 map) additional injector controller giving the extra fuel needed under boost.
I'm not a tuner, but I do MAP the injector controller with good results.
Here is the first 9 second pass that car ever ran turbo (20psi) & I ever tuned a car up to run. The bad 60' is due to wheelspin, as the car has run 1.29 60's. The clutch was slipping killing MPH, but it still ran in the 9's.
60' - 1.449
330' - 4.068
1/8th- 6.333
MPH - 108.32
1000'- 8.298
1/4 - 9.975
MPH - 133.35
After getting tired of 20psi we have run up to 35psi with interesting results & hope to run 9.2's this coming spring (cool temps).
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
206er
Post by 206er »
holy crap
what axle and trans are you running in that thing?
also I thought there is a minimum wheelbase for engine swaps in NHRA? the starlet is a short ass car.
BXSS
Post by BXSS »
There is a minimum NHRA weight of 2200lbs with driver.
The short wheelbase means it is a handful going down the track.
Engineering types say the wheelbase is unsafe @ times quicker than 7.9's, but PR racers have pushed these cars to 7.0.
The trans is a 4spd mid 70's vintage Toyota Celica tranny with a custom adapter plate for the Mazda bellhousing.
It cost exactly $150!
The rear is a ford 9" narrowed down with Mark Williams axles & spool, spinning 4.3 FD PRO Gears.
Heres the Link of a launch again-
http://bbs.legacycentral.org/viewtopic.php?t=32633
The next set of mods = GT45R turbo, BIG FMIC, 2 stage alky injection, Bigger tires, Electronic boost control (to be used as traction control on launch (Launch @ low boost, hit the button & get full boost @ the 60' cone)). It will get quicker!
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
Kelly
Post by Kelly »
Um, thats freakin awsome. :smt119
Hey, got any pics of your hachikuro?
BXSS
Post by BXSS »
I have like 1000 before pictures, but I'm in the process of restoring it so it it still a work in progress.
Long story short it is a Charcoal grey factory 4AG coupe, that was originally 2-toned silver over black.
After all the mechanical stuff is re-done (suspension(strut tops to bushings), brakes (m-cyl, SS lines, rotors, pads), steering, wheel bearings, fuel pump, LSD) it will get resprayed the factory colors.
It runs/drives now, & though it has no power it is a fun ride - RWD, Light (2100LBS), good weight balance / handling.
I hope to get it finished by next summer, but I have too many project cars so it may take a little longer...
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
mgroshong
Post by mgroshong »
i helped my buddy rebuild his 13b-rew, and it took about 1 hour and a good handfull of vasiline.....
so far it has held 20lbs from a gt4202.
and to talk alittle about the hot exhaust temps, he has had the manifold and turbo glowing white hot.... after a good highway pull.
also he just saw that he has some chunks missing from the turbine blades. so it got alittle hot. but hasn't blown up yet...
cars:
- 1991 legacy SS, stock
- 2003 s2000, turbo project
- 1991 crx dx RHD
- 1990 probe gt, 12 lbs, lowered
BXSS
Post by BXSS »
+1 on Alot of Vasoline for a rotary rebuild..
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
Hotshot
Post by Hotshot »
A guy I know used to run a 13B in a suzuki samurai. He blew that one up pretty fast. Put another one in. Blew that one up too.
Now he is just finishing swapping a 4.3L V6 into it from a blazer. No more rotary for him.
