Are you familiar with our cars' clutch plumbing? 92-94 turbos have two hoses, each with a 10mm banjo fitting on each end. 91 turbos have a slightly different setup; if I remember right it has one hose like that, one hose with the same fittings as the brake lines (a 10mm banjo on one end and a M10x1.0 female flare on the other), and one hard line.
Don't worry Shane, I'll need one of those too for the wife's 5MT. The stock line allows for a soft pedal feel even after a new clutch & pressure plate. I figure a braided line & good quality fluid will greatly help that problem.
Ok, I'll have a couple things to get for both cars in mid January with school refund money. So I'll make sure to let you know about a week ahead of time.
Reason - Cool, when you get the 1st-gen stuff I'd like to see it; I have a pseudo homebrew setup right now but it'd be nice to have a 1-piece stainless steel braided clutch hose.
I don't have a picture of the adapter, it's really more of a male - male coupler.
The 1-gen MC's have a female thread port, same size/thread pitch as the hose pictured above. So if you get a male-male coupler with same size thread as the hose then you just screw one end into the hose and the other into the MC.
It was actually the same as my new 02' WRX MC now that I think about it.
