Engine stutter under hard acceleration? (searched)
Fkyx
Post by Fkyx »
Hi. My roommate and I are stumped by this one. When I'm hard on the gas, the car sort of stutters in and out of power. It's not a consistent type of stutter... here's a video:
http://www.youtube.com/watch?v=GU1lEaa-gPI
It's hard to pick out the stutter -- any time you hear the engine sound "cut out" for a split second and then come back, that's the stutter... not a sound problem.
The kicker is it doesn't do this while the engine is still warming up. It accelerates smoothly, no problem, if it's not at "running temperature". Also, unlike some of the other threads I found in my search, the car doesn't bog down at all at idle. There's no stutter at idle. It runs perfectly until it's warm and I get on the gas hard.
The boost gauge shows a constant 9lbs (that's what I'm running).
I figured this may be related to that carb fuel filter that was sitting after the normal fuel filter, but after deleting that and still being plagued with the problem, I'm more than sure it's unrelated (unless the carb filter damaged something to cause this problem). So I cleared, then checked my codes, and in addition to the 22 and 23 I had before, I now have a code 24 on my hands. The car also smells like it's running rich after deleting the carb filter. I looked into replacing the O2 sensor, and I plan to get around to this in the next week or two unless this stuttering problem makes it unwise to do a 300 mile drive home.
Any thoughts? Sorry about the long winded post.
subieal
stuttering car
Post by subieal »
Hey i had a simmalar problem with my car a while back and it started happening as soon as i got rid of the air box and put a high flow cone directly after the MAF. My roomate and myself battled it forever and finally i put cold air in my car and the problem went away so we figuered that having the air filter so close to the MAF causes some funny turbulence making for a weird air flow reading. So if you have a cone filter id try spacing it away from the MAF a little bit and also make sure that the wire inside the MAF is clean. Hope this helps!
asc_up
Post by asc_up »
i'm not sure what the problem is, but your car sounds awesome!!
Fkyx
Post by Fkyx »
asc_up wrote:i'm not sure what the problem is, but your car sounds awesome!!
Thanks. :P That's all the PO's fault, though. I had nothing to do with it... but I did have the balls to make the blind purchase. Here's the exhaust video:
http://www.youtube.com/watch?v=FBvBGz9ZIOA
Steeper
Post by Steeper »
my car has a cone bolted directly to the MAF and I know of several other 2.2 turbo and NA that are the same, havent seen any problems from it yet.
93 impreza wagon
95 v2 STI RA drivetrain
FMIC
002.5 RS bumper and 95 wrx hood
SS 3in TB
ciper
Post by ciper »
Have you ever replaced the spark plug wires? Can you get the car in complete darkness and have someone rev it while you watch for sparks?
Fkyx
Post by Fkyx »
I can do that. When I look for sparks, I'm assuming they're a bad thing, correct? And if there are sparks I should replace the spark plug wires.
I'd start with plugs & wires. You may want to take a spray bottle and mist water over the plug wires & coil pack and see if you see any sparks.
subytech
Post by subytech »
Steeper wrote:my car has a cone bolted directly to the MAF and I know of several other 2.2 turbo and NA that are the same, havent seen any problems from it yet.
Seems to depend on the car, I've seen some that dont have any problem and some that will bearly run.
Yeah, it sounds like classic ignition issue. In my experience, these cars eat wires, but a set from Magnecor will probably be the last set you'll need.
Fkyx
Post by Fkyx »
I've been looking into wires. Unfortunately, they're rather spendy when I take a look at my financial situation. I'm going to start with *checking* the O2 sensor, then the fuel filter, and if all of that checks out, I'll move toward buying a set of Magnecor wires. I think in the process I'll grab a new set of NGK plugs.
I figured, though, that if it were an ignition problem, it would show all the time, not just under hard acceleration in gear.
biggreen96
Post by biggreen96 »
just the other week my car was acting up REALLY bad, misfiring and popping like crazy, I couldn't even get up the hill to my house it was so bad and it finally died and wouldn't restart. I took the cam and crank sensors out and wiped the crap off them (there seemed to be a lot) and it started back up and ran well.
Where is the cam and crank sensor??
biggreen96
cam: right hand side of engine on the head, one bolt holding it on, it gets reading from the cam pulley. very easy to get at.
crank: under and to the left of the alt, above the crank pulley, also one bolt holding it on, also fairly easy to get at.
hope this helps.
Fkyx
Post by Fkyx »
I took the O2 sensor out and cleaned it today. That didn't fix the problem, AND it's still running rich! (hoping I don't have to replace it all together) I'm going to go ahead and replace the fuel filter tomorrow, and if that doesn't fix the stutter, I'll order myself some new Magnacore cables.
If the car is running a Walbro 255LPH pump, but is still on the stock ECU, would that cause it to run rich?
If the fuel filter was bad it wouldn't be running rich.
Fkyx
Post by Fkyx »
Alright. I'll see if there's a place around town that stocks the Magnecors and replace those.
dzx
Post by dzx »
It's possible your timing jumped a tooth.
///M
'93 Legacy SS - part out
Boostedballs
Post by Boostedballs »
Any updates on this? I have the same issue with my 91 turbo. My car is bone stock and no mods to anything but a K&N filter.
I've replaced the:
fuel filter, plugs, air filter, PCV valve.
The problem still exists if I disconnect the:
O2 sensor, knock sensor
I'm starting to think the cats must be clogged or the plug wires are shot.
PS: (from earlier reply about plug wires failing) The plug requires more voltage to jump the gap as pressure increases. Sort of reverse logic, but that's the way it is.
not trying to hijack, just trying to revive the thread...
Air-to-Water Intercooler, VF-39, 550 injectors, AEM FIC, stainless race header, 3" stainless exhaust, 75hp Nitrous, 150psi H2O injection, intake mods, stock: long block, 4EAT, ecm.
what huh
Post by what huh »
i had this problem with my 98 GT-T i replaced the air filter, plugs and wires. And it helped a little but the problem was still bugging me. Then i had to replace the fuel filter and then i was running very rich causing the same problem but worse. And then i got it retuned and it ran like i never thought it would. It was awesome but dealing with the problem did suck. So i would recomend replacing your fuel filter also.
1998 Legacy GT-T ... sold
livestrong14
Post by livestrong14 »
Plugs, Wires, check all vaccum lines, and all of your IC clamps. Especially look at your TMIC to Throttle Body clamp.
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
