set of rear CV axles removed from 93 SS
VF11 no shaft play, worked great when removed
EJ22T heads, also worked great when removed
glass from the same SS, all door glass already removed and ready to be shipped
Wiring harness from the car - The complete wiring harness, minus the engine harness, the harness has been cut to remove everything not pertinent to the car running, but project has long since been abandoned, so you get both halves or the harness, heavy like 60lbs +
set of 4 Aluminum 14" Legacy GT rims from a 94 Legacy GT wagon - They look like this:
http://catalog.thewheelwarehouse.com/images/68685.jpg but are gold, not silver
Steering column trim
Switches, HVAC blowers, cup holders, speaker grills, etc...
i have tons of legacy parts, so email me if you need anything. Need some Christmas dough so some stuff's gots ta go
Thanks!
parts for sale
parts for sale
Hey, do you have any of the tubing/.hoses?
I need the tube that connects the air box to the turbo, as well as the PCV hoses (plastic + rubber)
Also looking for a turbo engine cover but I don't need that to get the car running... Let me know what you've got!
1990 Legacy LS wagon, FT4WD 5MT
1987 GL Turbo wagon, DR4WD 5MT
1992 Dodge Ram 4WD Turbodiesel 4AT
1991 Legacy Turbo Sedan 4AT :(
1992 SVX LS-L
1992 SVX LS-L
