High Idle... Finally fixed
tahiti350
Post by tahiti350 »
My '90 Wagon has started idling high in the last couple of months, and seems to be getting higher. Right now it's at 1400-1500 warmed up (after driving to work) with everything off. Mileage is down a little, 1-2 mpg, aad power is off a little. It still doesn't like to start when cold, and I have to hold the throttle to keep it running for a couple of seconds to let it stabilize.
I've looked at most of the vacumn lines, etc, and can't see anything out of the ordinary. I do have a good scan tool, but I can't find the data port now.
'90 Bermuda Blue L Wagon (Wife's),
Auto, AWD, Now with 275K + miles!
2005 Outback, 2.5 AWD (wife's new daily)
Your coolant temp sensor may be going out...
tahiti350
Post by tahiti350 »
That's what I was thinking, as the idle when cold is fine once it stabilizes...
Anyone know where the diagnostic port is located? I've hooked up once, but that was over 2 years ago.
86ruguy
Post by 86ruguy »
The data port should be under the steering column
92wagon (wife's)
92 sedan (sold)
91 ss no mods (sold)
88 GL Wagon (broken)
tahiti350
Post by tahiti350 »
Thanks, that's what I thought, but couldn't find it this morning. Was in a hurry though. Will look at lunch and find it again.
internetautomart
Post by internetautomart »
what data port?
I thought all we had were those connectors that you hook together :shock:
94 BC w/ AWD Sold 6/25/08
92 BJ Rust bucket gone
90 BC (I think) Stripper, gone since 2k
86 GL10 Turbo 4wd, Gone since 99
asc_up
Post by asc_up »
isn't a data port for OBDII??
am i missing something here?
scuzzy
Post by scuzzy »
there's a yellow six pin (I think) subaru select-monitor data port that you can use either with vrg3's scan tool or a subaru select monitor.
#82 M4 TRSCCA Rallycross
internetautomart
scuzzy wrote:there's a yellow six pin (I think) subaru select-monitor data port that you can use either with vrg3's scan tool or a subaru select monitor.
pics?
scuzzy
Post by scuzzy »
pics?
sorry, it's nine pin.
http://www.graphics.cornell.edu/~v/b10scan/
tahiti350
Post by tahiti350 »
Okay, looked at that one this morning, and thought that was it, but can't find my Subaru adapter.
Data port/diagnostic port/the connector that you hook to to see what the car is thinking... whatever.... I couldn't remember the "proper" term, but looks like most figured out what I was talking about.
internetautomart
pics?
does anyone know if the software can run from inside windows?
most new laptops lack any serial or parallel ports so I'd need to run a USB to parallel adapter which I doubt is supported by the boot disc
No, it cannot run from inside Windows. You'll need to find an old laptop or a PCMCIA parallel port with DOS drivers.
tahiti350
Post by tahiti350 »
Okay, did a little more testing today. Pulled the plug off the IAS solenoid, and the idle dropped to about 800-900 rpm, but really rough. Started pulling plug wires adn the two front cylinders aren't firing, but I have lots of spark at the coil...
Plug wires are 1 year old, plugs at the same time.
So, lack of power, computer correcting to overly high idle, crappy fuel milage, and 2 dead cylinders. Does this all sound like a bad coil??
tahiti350 wrote:Started pulling plug wires adn the two front cylinders aren't firing, but I have lots of spark at the coil...
Wait, I don't understand. You found that removing either of the front two plug wires made no difference in how the engine ran? But what does it mean that you have lots of spark at the coil? Could this be two bad injectors?
If you are in fact getting no spark on either of the front cylinders, I would also unplug both front fuel injectors. You can run for a while that way; the engine will run roughly but at least you won't be throwing raw fuel out the exhaust.
Oh -- also, it could be a bad ignitor rather than a bad coil.
tahiti350
Post by tahiti350 »
When I pulled the plug wire at the coil it would arc from the coil terminal to the coil mount bolt. As I put the plug wire back on it was jumping about 1/4" to 3/8" to the terminal, but still not firing the cylinder.
Would a bad plug cause both cylinders to drop offline? I swapped the plugs on the passenger side, but didn't pull the driver side plug to look at it, just ASSUMED that the coil was dead at that point...
Maybe I need to look deeper??
The coil can't be dead if it's giving you spark. I suppose it could just be a weak spark, but it's not dead.
A bad plug could cause both cylinders not to fire, yes. If the side electrode is missing or the gap is way too wide, the spark won't properly be able to jump the gap, which it has to do on both sides.
tahiti350
Post by tahiti350 »
okay, I'll check the other plug and see how it looks. Would be great if that's all it was....
Thanks for the sanity check!
tahiti350
Post by tahiti350 »
OKAY, next batch of troubleshooting... It's running on all 4 cylinders again, pulls like a freight train, smooth, but still idling high (now about 1600 rpm), and seems overly rich....
I'm thinking AIS is bypassing or bad, and/or a bad temp sensor?
When i disconnect the AIS connector the RPMS drop to around 800, right back to 1500 when I plug it back in again. This is hot BTW.
ALSO, on intial cold start it will start and then die. To get it running I have to give it throttle while cranking, then hold the rpm's up for about 5-10 seconds then it will idle. any otehr starts after that (while warm) are turn key.
Try resetting the ECU (with the green and black connectors). It may have learned to keep the IAC valve's duty cycle high to keep the engine from stalling, and now that the misfire problem is solved it's idling really high.
The cold start problem is probably unrelated. Coolant temperature sensor, perhaps?
tahiti350
Post by tahiti350 »
vrg3 wrote:Try resetting the ECU (with the green and black connectors). It may have learned to keep the IAC valve's duty cycle high to keep the engine from stalling, and now that the misfire problem is solved it's idling really high.
Thanks for the input, but where are the green and black connectors?? doesn't disconnecting the battery for a while do the same thing??
internetautomart
the green and black connectors are in the wiring nest under the steering column.
Disconnecting the battery and pressing the brake pedal may do it, but not necessarily as reliably. Give it a try; if it doesn't do the trick, then try the connectors.
For information on the green and black connectors, read the sticky threads and look for the post on how to read ECU trouble codes.
internetautomart
vrg3 wrote:No, it cannot run from inside Windows. You'll need to find an old laptop or a PCMCIA parallel port with DOS drivers.
got an old laptop
made a boot disk
now I need to make the cable and find the connector on my car.
