vibration
awssubaruls
vibration
Dear friend
i have a problem in my subaru legacy wagon 92 .that when i start engine it maks vibration in hardly noses . when i press fuel pad it disapear. aslo disapear when i run ingnie in more speed. i changes the spark. nothing happin the problen still yet
thanks alot
thanks alot
Arctic Assassian
I think he means the gas pedal. I really don't think English is his first language.
awssubaruls - Did you replace the spark plug wires as well as the plugs?
awssubaruls
legacy 92 LS
[quote="evolutionmovement"]I think he means the gas pedal. I really don't think English is his first language.
awssubaruls - Did you replace the spark plug wires as well as the plugs?[/quote
Dear all
i replaced these items
1- fuel pump
2- fuls filter pupm
3-fuel flter
4-spark
5- spark plug wires
the main problem is when a stop my car in any place my enghine start varbrated. raised up my car .it disapear
reagrds
Aws N.
iraq-baghdad
Dear all
1- fuel pump
2- fuls filter pupm
3-fuel flter
4-spark
5- spark plug wires
reagrds
Aws N.
iraq-baghdad
I wonder if it could be a drivetrain problem. If it only happens when he stops, and is off the gas...
awssubaruls: Does the car have a manual or automatic transmission?
awssubaruls
LS 92
Sir its 5 manual transmissionFkyx wrote:I wonder if it could be a drivetrain problem. If it only happens when he stops, and is off the gas...
It still sounds like misfiring, but if the coil was bad it should do it all the time. Maybe a dirty IAC (idle air control) valve.
awssubaruls
yes sir
that's right like misfiring, plz sir have you a piture for IAC location and how can i clean it.evolutionmovement wrote:It still sounds like misfiring, but if the coil was bad it should do it all the time. Maybe a dirty IAC (idle air control) valve.
regards
There is a small tube connected to the air intake follow that tube to the piece below the throttle body and you will see it. You can just spray some throttle body cleaner or pour some seafoam in that tube while you have someone reving up the engine.
Here is a pic from USMB forum
http://www.ultimatesubaru.org/forum/sho ... light=idle
If you look at your engine from the front of the car, the IAC valve is mounted to the intake manifold to the left of the throttle body and below the PCV valve. One way to clean it is described here:
http://bbs.legacycentral.org/viewtopic.php?p=1199#1199
If you follow that advice, be sure to mark the position of the electrical portion of the valve before you remove it, so you can put it back in the same position.
Another possible reason for misfiring at idle is a vacuum leak. You can locate vacuum leaks using starting fluid:
http://bbs.legacycentral.org/viewtopic. ... 427#102427
awssubaruls
vacuum
i hope if u have a picture that explane how i do the procedures of vacuum leak. also what type of fluid i use.
many thanks frineds for help
I don't have a picture, but it is a very easy task.
You need an aerosol can of "Starting Fluid." It is normally used to help with an engine that is having difficulty starting, and is sold at auto parts stores.
With the engine running, you spray the starting fluid in short bursts in various places around the intake manifold.
awssubaruls
What are these items?
guys what is type of items in these img ?
1- http://img529.imageshack.us/img529/6103/p1090027fi1.jpg
2- http://img84.imageshack.us/img84/8444/p1090028vx7.jpg
3- http://img84.imageshack.us/img84/5686/p1090029ge9.jpg
Regards
Regards
awssubaruls
Ecu
i don what u said . its ok .but i have another problem when i do this .chek engine what i turn on the engine.vrg3 wrote:I don't have a picture, but it is a very easy task.
regards
awssubaruls
Ecu
regards
Matt Monson
- quasi-mod-o
I deleted your other threads. In the future, please don't start a new thread for every little addendum to your initial questions. Furthermore, please use titles that reflect the problem you are asking about inside the thread. "Hi again" is not an appropriate title for a tech thread.
As VRG suggested, most of the information you need is easily found by reviewing the stickies. They should always be your first resort to finding answers. Your second resort should be using the search button. IF both of those methods fail, then it is appropriate to start a thread.
Lastly, if you make an effort to spell properly and capitalize you will get a lot more help. Many of us are adults and I for one just close the thread and move onto the next one when it looks like it was typed by a third grader. Even if English isn't your first language, there are many translation software packages out there that will do a pretty good job of converting your native language over to ours...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
The first picture looks like something that is part of a mechanical fuel injection system or carburator. I've got a manual somewhere that does cover the carburator, but I have to find it.
internetautomart
Yeah....that's what I was thinking.....but I haven't heard of any with mechanical fuel injection.
internetautomart
me either, but who knows what they got in iran.
israel got a 1.8 legacy in the beginning while we got a 2.2. didn't do any in depth research into which 1.8 it got. the cars were / are badged 1.8
94 BC w/ AWD Sold 6/25/08
92 BJ Rust bucket gone
90 BC (I think) Stripper, gone since 2k
86 GL10 Turbo 4wd, Gone since 99
awssubaruls
legacy 20.L
my car Legacy wagon 1992 Ls, 2.0L. i import it from holland in 2003.internetautomart wrote:me either, but who knows what they got in iran.
from that time its very suitable car to me.
awssubaruls
sir and the second picture what is sign to?. i have in my car four fuel injectors. so whau my car built in mechanical fuel injection system .note that some mechanicals here told me that its gas system and convert to petrol system. i think its wrong ideaLegacy777 wrote:The first picture looks like something that is part of a mechanical fuel injection system or carburator. I've got a manual somewhere that does cover the carburator, but I have to find it.
Regards
SemperGuard
Is this really necessary? He's obviously not fluent in english, do you need to point it out and put him down at the same time? You can get the meaning of what he's asking, so why tell him to "make an effort" to speak fluently? This isn't english class, just answer the guy's question, or don't. If you knew a decent amount of a foreign language, and posted questions on a forum in that language(or even went to that country), would you not want people to be somewhat understanding of your lack of the language? Or would you want everyone to tell you to make an effort to learn the language before you post again?Matt Monson wrote:Lastly, if you make an effort to spell properly and capitalize you will get a lot more help. Many of us are adults and I for one just close the thread and move onto the next one when it looks like it was typed by a third grader. Even if English isn't your first language, there are many translation software packages out there that will do a pretty good job of converting your native language over to ours...
