Does anyone know what offset we are supposed to be using on the BC-BF's? Or is this width dependant?
-Sambo
<http://rd.yahoo.com/M=190481.1393724.29 ... direct.com> www.newaydirect.com
<http://us.adserver.yahoo.com/l?M=190481 ... =165495834>
Wheel offset
Wheel offset
If I'm not mistaken the offset for all Subaru made
after 1990 is +53mm
Jay Erlenbach
92 Legacy Turbo Sedan
--- Sam & Beth Barrett <LEVATHIAN@sprintmail.com>
> -Sambo
Do You Yahoo!?
Yahoo! Auctions - buy the things you want at great prices
http://auctions.yahoo.com/
after 1990 is +53mm
Jay Erlenbach
> -Sambo
Do You Yahoo!?
Wheel offset
The offset actually changes from the high 40s to the low 50s, i
think, depending on the wheel width. I'm pretty sure my OE Turbo 6",
GT 6.5" and my new RS 7" have increasing offsets to clear the stock
struts. The 7" RS has noticeably more offset, perhaps 3-5mm, more
than the 6.5" GT.
Regardless, they're all right around 50.
--- In BC-BFLegacyWorks@y..., Jay Erlenbach <legacy_productions@y...>
> after 1990 is +53mm
> Jay Erlenbach
> --- Sam & Beth Barrett <LEVATHIAN@s...>
> > -Sambo
> Do You Yahoo!?
than the 6.5" GT.
> after 1990 is +53mm
> Jay Erlenbach
> > -Sambo
> Do You Yahoo!?
Wheel offset
Dave, actually the wheel offset would be decreasing if it's movin away from the struts.
A positive offset or backspacing, sucks the wheel into the fender well, you need +48mm offset on earlier legacies. I have +45 on mine, with a little modification on the rear fender lip.
I believe most are are +50mm or around there.
Josh Colombo
jcc189@psu.edu < mailto:jcc189@psu.edu>
of beats and rhythm" - ME
-----Original Message-----
Sent: Tuesday, May 08, 2001 1:59 PM
Subject: [BC-BFLegacyWorks] Re: Wheel offset
than the 6.5" GT.
> after 1990 is +53mm
> Jay Erlenbach
> > -Sambo
> Do You Yahoo!?
<http://us.adserver.yahoo.com/l?M=190481 ... =317821531>
Josh Colombo
than the 6.5" GT.
> after 1990 is +53mm
> Jay Erlenbach
> > -Sambo
> Do You Yahoo!?
Wheel offset
I've just mounted 7x17" rims (et45) with 215/45 tyres on my car ('92
Turbo Wagon, European spec)... had to roll the guard lips, but
otherwise they fit ok.
With an et >48 I guess you don't even need to roll the guards...
maybe...
* Miki *
--- In BC-BFLegacyWorks@y..., "Sam & Beth Barrett" <LEVATHIAN@s...>
> -Sambo
maybe...
* Miki *
> -Sambo
Wheel offset
how about some pics ?
¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø¤º°`°º¤ø,¸¸,¤º°`°º¤ø,¸¸
Info: John Carlsson UK 92 Legacy 4 cam Turbo Estate
E-mail : penty@nettaxi.com < mailto:penty@nettaxi.com>
Sent: 09 May 2001 09:34
maybe...
* Miki *
> -Sambo
<http://rd.yahoo.com/M=190462.1393721.29 ... icated.com> www.debticated.com
<http://us.adserver.yahoo.com/l?M=190462 ... =804766207>
maybe...
* Miki *
> -Sambo
