The plan is to have four FF1000s on a curved bar so the middle two sit higher than the outer two. Like so:
The "C" part will fit through the grille and bumper cover to clamp onto the beam. Holes, will be tapped in the bottom of the C so that you can just crank on bolts from behind the grille. So today I started working on that "C" part, which I guess will be 2 pieces.
Here's some sort of a bracket I found in a room full of stuff we don't use anymore. I cut it in half:
It's going to go in here:
Needs some work on the mill, though:
(and yes I was wearing safety glasses)
First I evened out the top fairly half-assedly:
Then started removing material from the inside of the "L"
But I had a long way to go:
It was time for a different approach:
Except that was taking too long so I decided to use the bigger saw:
Much better:
Then I just needed to clean them up a bit:
That's looking better:
Also I have a new sticker:
And that's all. Tomorrow evening I'll do some bumper drilling and try to get a pair of lights mocked up and possibly installed.
