Hi
today in the morning when i start to heat my car i see vibrant Ide up to 2rpm and Zero. i mean my rpm not stable .
B.R
vibrant Ide up to 2 and 0?
You probably have to clean the IAC valve.
To bad in Iraq they don't have any car parts or additives so you can clean it. Your going to have to import some spark plugs, and wires from europe or asia man. How much did Subaru in the Midwest say it will cost for spark plugs and wires? Do you have WD40 over there? If you do you can spray that down the tube for the IAC and it should clean it out just fine.
thanks dude i'wll do itericem wrote:You probably have to clean the IAC valve.
