My old disks won't come off - suggestions please
Gerry
Post by Gerry »
I pounded on the old disks, heated them up, lubed them and those bastards will still not budge, I assume that they are rusted in place but I would like to know if I am missing something.
93 Legacy turbo wagon.
You need to heat them up more. You'll probably need something more then a propane torch, MAP Gas or an oxy acetelene torch.
I did the brakes & rotors on my old boss's eclipse. Had to use an oxy acetelene torch. I banged on those things for a while before doing that.
86ruguy
Post by 86ruguy »
You need to get a BIGGER HAMMER and hit the center area of the rotor.
I have done hundreds of brake jobs and never had to use heat.
Maybe a little WD40 on the hub area but never had to use heat.
BTW...when I say bigger hammer I mean like a mini sledge hammer.
92wagon (wife's)
92 sedan (sold)
91 ss no mods (sold)
88 GL Wagon (broken)
First, if you're talking about the rear brakes, make sure the parking brake is off.
Then, get two M8x1.25 bolts. The brake discs have threaded holes in them for exactly this purpose. Thread them into the holes evenly until the discs pop off the hub.
Post by 555BCTurbo »
Yeah, I made a puller for doing mine...out of a piece of flatbar and 2 bolts...took all of 5 minutes...and works great
New92
Post by New92 »
vrg3 wrote:First, if you're talking about the rear brakes, make sure the parking brake is off.
+1 - works perfectly.
1992 SS 5MT
DLC
Post by DLC »
I used the bolt trick on my rear rotors this summer and it did the trick perfectly.
Legacy Central
Gerry
Post by Gerry »
My rotors don't appear to have these holes, which kind of stinks.
So I guess I am back to heat and hammering.
93 Legacy Turbo Wagon EJ22T
98 Legacy Brighton EJ22E
01 GTP Special Edition 3.8L Supercharged
I can't imagine what Chinese junk (the cheap crap, not the boats) wouldn't have the holes. Spray the hell out of it with some good penetrant - Zep is the best, but PB Blaster is easy to find and let it sit for a day or two, maybe reapplying a few times in between. Thread a lug nut or two on the bolts and whack it as you rotate it from the back. Bearings don't like heat, so be careful going that route.
It's not a bad idea to put some grease on the back of the new rotors to keep them from bonding.
92ss satinsvoice
Post by 92ss satinsvoice »
i did the same thing. much better then risk warping other components with heat or weakening them.
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
Gerry
Great news, I got the disk off!!
Post by Gerry »
Purchased
2 x can "3 and 1" Penetrating Lubricant (in the orange can)
1 x 4lb sledge hammer
It dawned on me that if I were turn the wheels that I would have a better vantage point as the car is not jacked up too high. If you feel behind the disk there is a ring of teeth that match up with the hub. I sprayed a lot of the lube in there over a two day period. Then I pounded the perimeter of the disk with the sledge. Then I gave it about 20 good wacks on the back while rotating the disk. Then hammered one side of the front until finally I saw it move.
So I again started rotating the disk while hitting from behind and then it finally came off.
God love the sledge hammer, it makes a man feel mighty.
I am including some before and after pics (they were taken with my phone so the quality isn't all there.)
This picture is blurry but you can still tell what I am dealing with
No wonder it gets corroded the hub isn't solid. Water and salt have an open door. I wire brushed the hub down then I coated the perimeter with anti-seize. I shouldn't have the problem again.
Here is a close up of the corrosion in my disk, it's way worse than what the picture displays
Here is my new disk and pads, I am a happy man.
86ruguy
Post by 86ruguy »
AHHHHH!!!!!!! :D
The spoils of sucess.
:smt026
Looks good!! :smt038
92wagon (wife's)
92 sedan (sold)
Ack, your new discs also lack those threaded holes! Didja put antiseize on the hubs?
86ruguy
Post by 86ruguy »
QUOTE"I wire brushed the hub down then I coated the perimeter with anti-seize. I shouldn't have the problem again." UN QUOTE
92wagon (wife's)
92 sedan (sold)
I'm awesome at reading, and am never distracted by pretty pictures.
asc_up
Post by asc_up »
vrg3 wrote:I'm awesome at reading, and am never distracted by pretty pictures.
Hahahaha. I hate it when that happens.
Gerry
Post by Gerry »
The rear disks have holes.
subytech
Post by subytech »
86ruguy wrote:You need to get a BIGGER HAMMER and hit the center area of the rotor.
I would only do this as a last result, banging that hard on the hub can do bad things to a wheel bearing.
86ruguy
Post by 86ruguy »
That's funny because I've been doing it for 25 years and never had any trouble
92wagon (wife's)
92 sedan (sold)
subytech
Post by subytech »
Guess your lucky then I've seen it happen a couple of times, all be it on newer models but still.
