I have been testing an oil separator for JC Sports for about six
months. I just uploaded a picture of my engine and if you look at the
front of the engine on the passengers side
you will see a small clear tube, this is coming from the oil sep. to
the intake and carries all of the vented air to the intake. The
reason
it is clear is that we wanted to see if any oil was moving through it.
On the bottom there is a oil drain in to the valve cover and it
mounts
with one existing bolt. The old system actually will pull oil out of
the valve cover and other places and really makes a mess. All is
clean
and dry. I don't know when this will be available from them but will
check if you want me to.
oil separator
oil separator
Do check, i'd be interested in something like this.
the
to
> reason
it.
> mounts
of
> clean
will
the
to
> reason
it.
> mounts
of
> clean
will
