Iam about to replace the front wheel bearings on my 1993 legacy. I removed the spindle/hub from the car. I have a press, but want to make sure the process is done correctly (especially pressing them out and then back in correctly). Can someone please post a reply on the steps to press the old one out (including the inner hub) and the new one (inner hub and whole bearing set) in?
I took the grease seal off from where the cv joint mates to the hub. I noticed a retainer clip that sits right above/on the bearing. How do I go about pressing out the inner hub from the bearing? Do I press that one out first with the bearing still in the spingle/knuckle and then press the rest of the seal out? If so, does anyone have any steps or pics in doing so?
Thanks,
Paul
Front Wheel Bearing replacment time on my 1993 legacy
pdigiacinto
