06 intercooler question (with pic) i need a flange
Saskatoon Subaru
so i got my intercooler today and i'm pretty excited, but i have maybe a dumb question, whats this hole for?
Last edited by Saskatoon Subaru on Thu Aug 30, 2007 3:04 am, edited 2 times in total.
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
That flange is for your recirc valve, or BOV, what ever you decide to use. Look at some of the posts with pictures of IC's like yours to see how others have fabricated a flange to work there.
http://www.main.experiencetherave.com:8 ... ey_ic3.jpg
For example.
For example.
Saskatoon Subaru
Saskatoon Subaru
Nice looking flange you made there did you do the welding your self?
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
Saskatoon Subaru
SuperRallyRoo
I got one on ebay for like 12 bucks....
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
16 WRX | 6mt | fa20
ThreeEyedBandit
ThreeEyedBandit
Here it is, the only difference is the engine is in a 85 GL wagon so I can have the intercooler sit farther back for the coolant tank. The hardest part was just getting the nut to 'sinch' down in the inside of the intercooler. I just used my finger to get it lined up then used a stereo removal tool to hold the nut while I tightened it down.
Matt
Matt
Wow, that looks terrific! Jackpot!! The 69 cent question is what is that piece called and where at Lowes did you get it? Please, the more info the better...
Oh, and what's it made of PVC? Can it handle extreme temps?...
ThreeEyedBandit
It is found the the electrical conduit section, called a 3/4" 90 Degree Connector. Lowes #116027, here is the link to their page.
http://www.lowes.com/lowes/lkn?action=p ... LN20EA-CTN
Matt
Matt
Uh, I'll be heading down there tomorrow for that sweetheart....
So how hard do you crank it down and I'm not sure I know what a stereo removal tool looks like but I think it's a needlenose with right angled tips...
However, I'm not sure if this material is rated for engine temps?
Folks, what do you think we're talking here for ambient temps?
This gives some temp rating for the material...
http://www.carlon.com/Master%20Catalog/ ... ochure.pdf
Thanks again for posting. If this works out this will save a lot of folks grief.
AW
AW
Arctic Assassian
ThreeEyedBandit
I have been running it for two months so far and no problems yet. I think the temps will be fine since it it on the opposite side of the turbo/exhaust, and the scoop keep cooler air moving down and lets the hot air keep moving out the top when not moving.
The useful part of the stereo removal tool is just a piece of 1/16"x1/4" metal with a short 90deg. bend on one end used to hole the nut inplace, then keep it from rotating. This work well just kind of a pain to install.
Matt
Matt
ThreeEyedBandit
ThreeEyedBandit
I just beveled the non-threaded portion where it attaches to the intercooler so it will seat down to the BPV hole, and then just snugged it down fairly tight. This week I will get another one and do a quick write up on how I installed it.
AW
ok just got the plastic part from lowes, to do the recirc as i dont have a BOV..unless the car comes stock with one i dont know about.
thats the only part you need for the install right?
i have the o6 wrx TMIC
I think you need the turbo XS blowoff adapter plate or an eBay version of one.
http://www.rallysportdirect.com/shop/tu ... p-126.html
But double check with the Brat guy.
