OK Here Goes
Locked
daniel.wilson@db.co.nz
OK Here Goes
Post by daniel.wilson@db.co.nz »
Cold air box, pod filter, and new plenum, bored out throttle body to
64mm (almost straight through), 600cc injectors (800cc for drags),
modified fuel rails (larger and fuel fed from both ends), huge bosch
in tank fuel pump, rising rate fuel regulator, alcohol and water
injection, EJ22 BPM stroker kit, balanced and blue printed, very
large con rod bolts, spigot the o-ring the block, Subaru EJ25 Outback
heads (large bucket, solid lifter, inlet ported to match EJ20
manifold), strapped heads, Group A plus cam profile, ported STI
manifold, tuned length extractors, standard TD05 turbo (mounts
twisted and right now being totally modified with custom impeller's
and housing's), 3" mandrel bent stainless exhaust no cat and Borla
muffler, block runs no sleeves because the sleeves keep splitting
(the alloy block has a special coating), on spark plug coils, new
link II computer and all the options and big front mounted oil cooler.
RS twin turbo clutch and gearbox retrofit, and new rear LSD (not twin
turbo or late model).
Bilstein Group N rally suspension front and rear (with progressive
springs).
Slotted rotors and comp 9 race pads.
Changes to come:
Dog box, bigger wheels and Porsche GT3 brakes front and rear, strut
brace, complete the Nolathane bush changes, modify the strut system
to allow adjustable platform and finally up rated sway bars.
I am sure I missed stuff, but I am sure that will do.
Dan
acroxford@hypermall.net
OK Here Goes
Post by acroxford@hypermall.net »
Hi Dan,
I hadn't thought of that special coating haven't seen it for
years.
Al
Outback
cooler.
twin
> springs).
> Changes to come:
> Dan
Mark Ward
OK Here Goes
Post by Mark Ward »
Damm! that must be one fast car!
Where did you get the group N Bilsteins?
Mark
>springs).
>Changes to come:
>Dan
OK Here Goes
Not at the moment, it is on axle stands, I am trying to get the
flyhweel off to lighten it.
I just got them in New Zealand from the top suspension place in NZ.
Dan
> Mark
Locked
