Start with an engine on an engine stand.
The intake manifold has already been removed, so no pics on that removal. Also, I neglected to take a before photo.
Turn motor upside down on the engine stand. Using a 14mm socket remove the 6 exhaust manifold nuts and pull manifold off. This one looks weird because it is a twin turbo exhaust manifold. Using the 14mm socket, remove the 4 bolts holding the motor mounts.
Next to remove is the oilpan. Use a 10mm socket. Then whack repeatedly with a rubber mallet. The dipstick needs to be removed first. On the top of the block is a 10mm bolt holding the dipstick tube. Remove bolt and yank dipstick tube out of oil pan.
Next remove the eight 10mm bolts that hold the oil pick up tube and splash guard. Don’t drop them into the engine!
To remove the oil cooler, you need a deep socket 24mm. Remove oil filter. Haha. The socket fits over the threaded section that the oil filter screws onto. This bolt/tube is about 3-4” long. Undo the two hose clamps on the hose FARTHEST away from the cooler and remove the cooler and two hoses as a unit.
