2.2 legacy turbo boost
boarderbw
Post by boarderbw »
I have a 1991 subaru legacy turbo (ej22t) and im getting a boost guage and boost controller for it. What is a safe psi range for it? Everything else on the car is stock.
asc_up
Post by asc_up »
10 psi is the maximum that you should run without an intercooler. Stock boost is 9 psi, so it's obviously not that much more.
If you put in a 3" turbo back exhaust you'll notice some power gains, but wait until you install an intercooler and then you can turn up the boost.
boarderbw
Post by boarderbw »
ok so if i get an intercooler how many psi can i run?
1991 legacy turbo
Arctic Assassian
Post by Arctic Assassian »
If you get an intercooler, I think without gettin a FCD(Fuel cut defender) the max is 15, depending on what elevation you are at. After you get some sort of FCD, you can run up to as many as you can get that little turbo to put out.
Kickin' it old-school.
asc_up
Post by asc_up »
The fuel cut on our cars is at 12.75 psi or more.
A fuel cut defender is easy to make, just search for a thread on how to do it. The VF11 (stock turbo) is very efficient at more than 12-13 psi though...
dscoobydoo
Post by dscoobydoo »
Honestly, I would not suggest raising the boost until you have more/better mods to support an increase in boost. The VF-11 can do more than the 11-12 before fuel cut, but without an intercooler and a better exhaust, you are not going to see much in the way of gains.
I would suggest locating a 06-on wrx intercooler, and then maybe buying a used good 2.5-3 inch exhaust on Nasioc and modifying it to fit.
I received more power from the exhaust modifications than i really did upping the boost 4 lbs.
We really should do a sticky on suggested order of modifications.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
Post by SubaruNation »
AAAAAAAAAND!
1. exhaust
2. de-snorkify! :smt040
3. Coffee cup mod it to pieces
4. 2,5rs Hood scoop :-D
5. Intercooler
6. Manual boost controller
7. boost guage
ha ha like that?
boarderbw
Post by boarderbw »
ok thanks. ive heard alot about the coffee cup mod and desnorking but i dont quite understand them. Does the coffee cup mod give me horses or does it just sound cool? and is desnorking just removing the intake silencer under the fender?
1991 legacy turbo
boarderbw
Post by boarderbw »
oh ya and im planning on putting an impreza outback hoodscoop and a sti downpipe on it
1991 legacy turbo
Post by 555BCTurbo »
boarderbw wrote: Does the coffee cup mod give me horses or does it just sound cool? and is desnorking just removing the intake silencer under the fender?
It just sounds neat...
And yes, you are right about the desnorking
i thought it added horse?
maybe only when you combine it with exhaust :?
smh0101
Post by smh0101 »
SubaruNation wrote:AAAAAAAAAND!
1. exhaust
5. Intercooler
7. boost guage
ha ha like that?
ACTUALLY:
1. Exhaust
2. Boost Guage (So you know whats happening and when)
3. Coffee Cup Mod
4. De-snork (Prolly same day as Coffeecup mod)
5. Intercooler
6. Manual Boost Controller (AFTER supporting Mods so you dont fubar something)
7. Fuel-Cut Defender
8. Hood Scoop from 2.5rs or whatever the hell you want.
9. Bigger Turbo
10. Engine Managment
11. Bigger Injectors & Probably a Walbro Fuel Pump
12. Um... I dunno... DOHC and Forged Internals????
13. Transmission... You may want to do something... Or wait for a disaster and use it as a good excuse for a newer better one!
But what about suspension and brakes and tires and wheels?? Or are we just talking power?
Because power is nothing without control ;) (And I speak from experience! :shock: )
asc_up
Post by asc_up »
Spencer is right.
Just about anyone on this forum or any other car forum will tell you that you need to be able to stop and turn better, before you go for speed.
But I know what it's like to want power. Hahaha. So do a few mods, but I'd at least recommend upgrading your brakes...
smh0101
Post by smh0101 »
asc_up wrote:Spencer is right.
Right now I'm running a 3" Turbo-back catless with a bad boost controller (crazy psi and Fuel-cut) on stock suspension and shot brakes. :shock:
(It will all be fixed this weekend. 8)
asc_up
Post by asc_up »
Hahaha I have a 3 in" TBE with stock suspension and brakes. It really doesn't give you that much power so I'm not worried.
I'm just saying, that before you go throwing on a big turbo with massive fuel injectors and a jet engine, do some other mods first.
smh0101
Post by smh0101 »
asc_up wrote:Hahaha I have a 3 in" TBE with stock suspension and brakes. It really doesn't give you that much power so I'm not worried.
Oh I totally agree with ya... I said it first lol...
I was mainly talking about the boost issue my car has. (Pulls like a mofo... but I dont want to F*&% somethin up)
And the 3" TBE sounds grrrreat!
asc_up
Post by asc_up »
Hahaha oh ok then.
I know. I love the Subie rumble mmmmmm. Haha.
skid542
Post by skid542 »
FWIW, the intake silencer (what gets deleted in the coffee cup mod) is one of the lowest sources of restriction in your intake tract. The snorkus has considerably more pressure drop across it. I believe it was COBB or one of the other notable/reputable subie vendors who did tests on all of this. They have their results posted. When I get home I will see if I can link it.
So while the coffee mug mod sounds cool, it doesn't really give you much.
Just FWIW.
Lee
1. exhaust
5. Intercooler
7. boost guage
ha ha like that?
ACTUALLY:
1. Exhaust
3. Coffee Cup Mod
5. Intercooler
9. Bigger Turbo
my bad :roll:
thats just the order i've done stuff so far :)
smh0101
Post by smh0101 »
It was only informative... I have more boost and no IC so... Yea, I'm really one to talk... lol
asc_up
Post by asc_up »
How much boost are you running?
smh0101
Post by smh0101 »
Not sure... i seem to get a boost spike that is like a shot of nitrous, then I hit fuel cut...
I can feel that its only a spike... Because all is well, then HOLY SHIIIITTTTT!!! BAM... Fuel Cut.
I'm good through about 4k RPM, then it spikes and hits at about 4700
Kinda odd. This weekend hopefully I can IC it and swap a controller from my wrecked car.
smh0101 wrote:Not sure... i seem to get a boost spike that is like a shot of nitrous, then I hit fuel cut...
and maybe i'll have my car and stuff there so you can help me do mine!! :smt040
