who here has replaced their turbo with a larger WRX turbo? whats the difference, how hard was the bolt up, and will the intercooler of the same year fit on without any abnormal modifiactions???
i have a line on some older WRX ICs and turbos and was wondering whats worth the trouble and what i should stay away from...
thanks gents!
mike
turbos and intercoolers
dfullerton
Do you mean for the north american modle
----- Original Message -----
To: <BC-BFLegacyWorks@yahoogroups.com>
Sent: Friday, July 06, 2001 6:13 PM
Subject: [BC-BFLegacyWorks] turbos and intercoolers
> thanks gents!
> mike
> thanks gents!
> mike
pjharj@sauk.com
If you want easy, stay away from the '96 and newer models. Much work is
required to make the intercooler work, cutting-relocating-welding-etc. The
turbo needs inlet mods and reclocking.
PeteH
> From: subaruracer755@cs.com
>Subject: turbos and intercoolers
>who here has replaced their turbo with a larger WRX turbo? >whats the
difference, how hard was the bolt up, and will the >intercooler of the same
year fit on without any abnormal >modifiactions???
>i have a line on some older WRX ICs and turbos and was >wondering whats
worth the trouble and what i should stay away >from...
PeteH
yeah on the american model... wish i had a liberty RS... but i want to put on
a larger WRX turbo and IC, and want to know which years to look at...
great, so i should be looking for a pre 96 WRX turbo and intercooler, does
the turbo bolt up to our stock up and down pipes?
i have the heat wrap and the know how, just need the parts..
any little tidbits would be helpful!
William D. Robinson
Turbos and Intercoolers
Every Subaru turbocharger I have ever seen bolts right up to a stock USA Legacy up-pipe, but the angle is a bit different for the down-pipe. It would be a great time to build a custom down-pipe. I sell the flanges ($25.00 US shipped anywhere in US/Canada) that allow you to weld straight into standard 3" mandrel bent tubing available from JC Whitney.
Bill Robinson
Bill Robinson
