Bad wiring?
greatjorb88
Bad wiring?
Post by greatjorb88 »
Hey there. Okay here it is, sometimes when I'm driving, and I brake, it's like I temporarily lose power within the car, sometimes it's only for a split second, but sometimes it literally shuts the car off and that's not happy. I'm wondering if this might be a wiring problem as I'm pretty sure my battery's fine. I could be wrong though. If it's not a battery problem, could someone please point me in the right direction where to start looking? Thanks alot.
'90 Legacy sedan blue
BSOD2600
Post by BSOD2600 »
Hook up a volt meter (like to the cig lighter) and monitor your voltage. What's it at while you drive and brake?
'11 WRX Limited
'94 TW | R.I.P.
internetautomart
Post by internetautomart »
as crazy as this sounds, check that the computer is in tight.
on my old GL10, I replaced the computer, but only put it in hand tight so the nuts loosened a bit. Turns out the computer grounded through those bolts and everytime I would turn it would lose the ground and shut the car off.
I would also check all the grounds to make sure they are tight and clean
94 BC w/ AWD Sold 6/25/08
92 BJ Rust bucket gone
90 BC (I think) Stripper, gone since 2k
86 GL10 Turbo 4wd, Gone since 99
