lifting the suspension
i heard that Outback struts and springs will lift a Legacy about 2", just dont know what years fit
i thought about getting nice wheels and tires and lowering it, but i just dont think it will ever really perform great without more money than its worth
i think id much rather have an off-road machine, since i already take it mudding fairly often, theres allot of stuff i cant get through
1990 Legacy LS, 4EAT
Arctic Assassian
northcoast
Arctic Assassian
Arctic Assassian
are there any negative effects of making strut spacers as apposed to getting outback struts/springs? i dont think i will be able to get as much lift out of it is the only problem i can think of, unless i swap the bolts for longer ones to put in a bigger spacer
You'd run out of 'down' travel on the lower arm sooner. I imagine they'd give you more positive camber, as well. But then, if you're lifting it, you're prolly not too worried about the handling.
