I'm really happy with her, although there are a few more things I'd like to do to her.
I would like to find a way to take the turn signals apart to paint the inside of them and I have some vinyl eyelids I want to put on. I want to get an rs hood scoop and put that on too along with body matching the mirrors. I also got some 92 tails coming in the mail and when they get here I am going to smoke the white part at the bottom out completely and give a dark glaze to the red. Then lower it when I get some money for some agx's. Oh, and tinting cause thats pimp.
Nice... And i thought you had he RS TURBO stickers on the fender to? Or am I just off...
i just did the rs scoop and it looks tits.
let me know if you need pics or anything, i have a bunch of the install.
it was way different than doing a wrx scoop
You'll only find an NA grill in the JY... and I would assume that they would be a helluva lot harder to make look 1/2 as nice...
smh0101 wrote:You'll only find an NA grill in the JY... and I would assume that they would be a helluva lot harder to make look 1/2 as nice...
I doubt it. The NA grille just has a few more little 'cross bars' on it. Nothing a dremel and some sand paper can't fix. It looks like he just cut off the cross bars, sanded it nicely and then mounted some mesh behind it. Probably had to repaint it somewhere along the line, too.
Just my 2 cents...
dropdfocus wrote:Customization is only limited by the imagination.
And possibly the skill level... I have the imagination...
Just my 2 cents...
yeah!
they'll look exactly the same when they're cut up.
it was a turbo grill (although i imagine you could do it with any grill). I just cut out bits in the middle with a saw and has a friend fill in the holes with epoxy before painting it black and putting some ricer grill behind it. Pretty simple, I got some pics if people are still needing help
super easy and looks great I suggest everyone do it.
I did the same with an n/a grille. It looks alright. I suppose. If you have low enough expectations.
I could (try to) post a pic if anyone's interested.
beatersubi wrote:I did the same with an n/a grille. It looks alright. I suppose. If you have low enough expectations.
PLEASE POST"EM!!!
And... since they have like 5 things to cut it would look more hacked up... AND you have to paint the crome crap... More work...
