So i got a killer deal on some STi Pink Injectors. I've searched and haven't found an answer to my question.
Do I need the N/A rails to use there? I found that you do for the STi yellow, but not the pinks. What would get these on the car?
STi Pink Injectors?
STi Pink Injectors?
~Bryan
'92 Legacy Sport Sedan - Winter fun
Stock 4EAT
5Speed swap and other goodies in the works : )
'03 Cobra - Summer trouble
All the bolt ons
463 WHP
480 WTq.
'02 WRX - Sold long ago :(
Stock 4EAT
All the bolt ons
463 WHP
480 WTq.
douglas vincent
[quote="555BCTurbo"]They should work fine in the stock EJ22T rails...
However, the car will not run right without some fuel map modification.[/quote
What are you smoking Nick?
They WILL NOT FIT! The pinks are topfeed, we use sidefeed.
Think either controlling it mechanically with a RRFPR. If that won't work possibly a dtec.555BCTurbo wrote:They should work fine in the stock EJ22T rails...
~Bryan
Stock 4EAT
All the bolt ons
463 WHP
480 WTq.
Stock 4EAT
All the bolt ons
463 WHP
480 WTq.
so I need the N/A rails then?douglas vincent wrote:555BCTurbo wrote:They should work fine in the stock EJ22T rails...
What are you smoking Nick?![]()
~Bryan
Stock 4EAT
All the bolt ons
463 WHP
480 WTq.
Stock 4EAT
All the bolt ons
463 WHP
480 WTq.
I am awesome at reading...
I was mistaken...I thought that he said that he bought yellows instead of pinks...
So yes...Doug is 100% correct...they will not even be close to fitting
And a rising rate will not solve your problems...
You will need to make ECU mods
douglas vincent
They won't work. Period.
You would need a different intake manifold that fits different heads than stock (like WRX heads.)_
douglas vincent
douglas vincent wrote:Nicks a NOOB!
A noob that has terrible reading comprehension tonight
Had I actually understood what I was reading...I would have known that they were topfeeds...
