Ok, Change of plans. I am now just going to part this out.
Here's what I'm looking to get out of the parts:
2003 NA ej25 SOLD!
KYB AGX with GC coilovers 325#/275# SOLD!
Whiteline Sway Bars (front and rear) SOLD!
XACT streetlight Flywheel SOLD!
OBX EL Headers SOLD!
Cusco Camber Plates SOLD!
VW 15" wheels with 185/65/15 Michelin x-ice snow tires. PENDING
I do NOT have the WRX wheels that are in some of the pictures.
All prices are OBO, plus shipping. Would prefer local pickup.
Also has:
2 good fenders
trunk lid
all 4 doors
seats
rear diff
nearly new front cv axles
all the interior trim
steering wheel
automatic seat belts
good clear headlights SOLD!
tail lights
corner markers SOLD!
you get the idea.
I'm also no longer interested in selling the whole car.
On any of the parts that make it so I can't push the car around (struts,camber plates,wheels) I need to find cheap replacements before I can let them go. I think I still have the stock strut tops but I'll have to look.
Oh and one other item, I have a set of 205/50/15 Avon Tech RA R-compound tires on steel wheels. 3 of them are about 2/3 tread and one is slightly flat spotted in one spot. about 1.5-2 32nds vs. 3 32nds for the rest of the tire. Looking to get $300 for these. The tires will be local pickup only. SOLD!
___________________________________________________________________
OK, my legacy is officially for sale. I was up in Spokane for a rallycross a couple weeks ago and broke second gear in the transmission.
Here's the list of mods currently:
Engine:
Has a 2003 NA EJ25 swap running off the original ECU (engine only has ~35-40K miles on it)
ACT Streetlite Flywheel
Freshly cleaned injectors
OBX EL Headers (not emissions legal (no cats))
K&N cone filter on stock intake tube
Suspension:
Legacy Turbo front brakes
15" VW wheels with 185/65/15 Michelin X-Ice Studless Snows.
KYB AGX struts
Ground Control Coilover Kit (325# Front / 275# Rear)
Whiteline Swaybars (22mm Front / 22mm Rear modified to about 25-26)
Camber Bolts
CUSCO Camber Plates
Custom short shifter
80/100W Headlight bulbs with relays
Hella ff75 driving lights with 100W bulbs with relay
The body has 303000 miles on it but is in very good condition considering. It has a dent on the passenger rear quarter panel and one on the driver side of the hood where I hit a dog a while back. The interior is in good shape it mainly just needs the carpet shampooed.
Here's some old pics: (i'll take some new pics when i get home tonight)
Here's the modified rear sway bar:
The engine runs strong. The timing curve on the 2.2 ECU is fairly aggressive so it does have an occasional pinging problem. I do have the 2.5 ECU that I will include with the car but you will need to come up with a wiring harness if you want to use it. A piggyback ECU could easily retard the timing a little bit and should fix the problem also. This motor is very strong. It will easily break all 4 loose on dry pavement. Assuming you're on street tires and not r-comps.
Jeremy
