Which motor is better?
Is a 2.5 DOHC better than a 2.5 SOHC and I've heard people say the 2.2 is better all together?
The Phase II SOHC is preferred to the Phase I DOHC. It's mostly due to reliability from the weak cylinder support in the DOHC models and their propensity to have headgasket problems.
The DOHC revs higher, but the SOHC has a much better torque curve and is easier to drive.
Some EJ22 models have problems also, but they're generally considered very strong engines.
Legacy Central
94TurboWagon
94TurboWagon
The 22B engine is the "best" 2.2L factory engine Subaru produced.
The EJ22 in the North American Legacy is a very, very good engine...if you replace the heads and the pistons.
Legacy Central
I agree with you, but once you swap heads (+ intake), pistons (& rods) all that is left of the original motor is the crank & block...DLC wrote:The 22B engine is the "best" 2.2L factory engine Subaru produced.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
...and?
If you're going to efficiently make over 300CHP you should have forged pistons. The stock rods are forged, but some lighter ones wouldn't be a bad idea. PnP the heads and intake manifold, or put on some WRX DOHC heads and you're breathing much, much better.
Legacy Central
douglas vincent
Matt Monson
- quasi-mod-o
Not an easy conversion. Do your homework before you run out and buy a SOHC Ej25 for that car...userm5898 wrote:Thanks I have heard from others that the sohc produces a higher torque curve. and my 98 legacy 2.5L DOHC has head gasket problems so maybe ill swap a sohc phase II.
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
Do you have any Phase II SOHC motors lying around? I might need one.
Legacy Central
Matt Monson
- quasi-mod-o
Again?DLC wrote:Do you have any Phase II SOHC motors lying around? I might need one.
Suby Hai!
Suby Hai!
Once you change all of the internals + heads just about any motor can make good power, but I still think you are right & the ej22t has the most potential for a 2.2L !DLC wrote:...and?
A friend of mine has a '05 2.5l with a cracked piston - (AVO turbo Kit...) that he was going to get rid of once his car is swapped.
I could get details for you if you are interested.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
96 Impreza OBS
99 Impreza OBS-T
My engine is still working fine, but it's eating or leaking coolant again. Might be the HG once more, or maybe a pinhole leak in the radiator or...
I'd be looking for something I could plop in, more or less, over something that'd need the case cracked. Thanks though.
Legacy Central
