VF11 + 06/07 wrx tmic intercooler install and other stuff
tank before ..
and after...
eh?
this one is smaller and WAY WAY WAY better.
it's not metal i guess, it's composite..?
and it fits great as you can see.
i bent the hard line in the 2nd photo to make the stock hose work.
really easy 2 do, the hardest part was getting the hoses off.
and after...
eh?
i just bought this because i'm getting hard- core boost leak.
...even though with the TMIC im only getting like 6 psi
http://www.siliconeintakes.com/product_ ... 9301d2eb1f
Ahem... with a intercooler on you can up the boost... at least a little.
i know but im waiting for my boost gauge to arrive still... supposed to be here thursday.smh0101 wrote:Ahem... with a intercooler on you can up the boost... at least a little.
i dont want to blow up my engine yet
OH!
I thought you had one... Yeah, wait till you have one.
thanks!
i've never seen them before but i guess they are from WRXes
this is where i'm stuck at now..
http://bbs.legacycentral.org/viewtopic. ... 625#248625
The link above for the 1.5" Hose is INCORRECT. The inner diameter needs to be 1.75"
here is the correct link...
I purchased the wrong hose from the link half way up the page... if you buy that hose, it will NOT work!!!!
On my second time through, i actually purchased this hose....
With the 45 degree outlet on the hose, and the 45 degree outlet on the VF11, this will make the final output placed at 90 degrees, which is where my samco hose sits out of the intercooler y pipe.... i believe this will work better, and i'll only need a straight piece of metal pipe to connect the two silicone pipes together... (samco and this new 45 bend silicone one)
-Luigi-
....Yes like nintendo
1987 GL10 Sedan 3.700 LSD
1988 XT6 FT4WD 3.900 Diff Lock
1992 EJ22T Touring Wagon 5MT Swap 4.111
