justy 5 spd
justy 5 spd
will a justy 5spd trannie work in a 1991 LEGACY TURBO??
The Justy was made, for Subaru, by Suzuki.
Will not work.
Will not work.
Legacy Central
But you could use a legacy 5mt in a Justy!
by EJ swapping it...
Eventually, after you made an engine cradle and bashed the firewall in for the bell housing, etc...
Legacy Central
**DROOL**smh0101 wrote:Can you imagine an ej257 swaped justy
Holy Crap!
That would be insane!!!!!
Jason
...and a mess. A stripped GC would be much stiffer and much, much easier to do.
Legacy Central
Someone actually swapped a 02ish WRX drivtrain into a Justy.
It was AWD & ran low to mid 12's on the stock WRX motor.
Search for WRX swapped Justy or something like that to find the web-page. The page has alot of pics & info on the swap.
I was actually thinking of making a RWD, EJ powered, back halfed (rear 1/2 of the car tube framed) Justy as it is basically the same as the KP61 Starlets 5-6 of my friends run now.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
Blasphamy!!!!! I'd never tinker with an authentic 360 (our local dealership has one from the first production runs).
Jason
He is a crazy Puerto Rican that had a KP61 Starlet with a Starion engine swap (in the mid '90s) who's boost control was leaving the wastegate disconnected....
I hope he leaves the thing alone, but he is too much of a speed freak to do that so I can see him putting a bike motor in.
360s have a rear mounted 360cc 2cyl engine (?-hp), so putting a bike motor in should easily triple HP (600cc sport bikes make 100WHP these days).
?- Rear diff, but I got the impression he wanted to mod a rear from a quad as this would get him chain drive & is about the right track width.
I never knew KP61s were popular rally cars until I got a rally vid from Europe & saw KP after KP running.
Again I hope he just leaves the thing alone as it is supposed to be pretty clean.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
96 Impreza OBS
99 Impreza OBS-T
