lol. Well I got sick of wind noise coming from the mirror and I am to lazy to remove it and all. So i grabbed a expansion foam bottle and spraye it in there. Little did i forget the window is in there... anywayss. now i see a mess when i lower the window next time it dries. I am hoping my wind noise is gone atleast
Or you can stick a 1/4 rubber hose between the pleats of the weather stripping around the door and gently compress the top of the side view mirror triangle mount, where the window channel is.
Well lowered the window. Just had to push it the first time. Then it was fine. No more wind noise woo!! Get a bit of binding though i just scraped a bit with a small scraper.
