An ECU scan tool for turbo and NA owners
ripplesouth
Post by ripplesouth »
DLC wrote:I hacked together a wiring harness and DB25 connector and got it working successfully on a Thinkpad 380ED (P166MMX).
I need to show this to Trey Cobb on Friday :D
Could you provide a show and tell on this setup?
DLC
Post by DLC »
Sure.
Read the first post of this thread. It contains all of the information I used. It was a very useful tool for myself and has been for many others.
Legacy Central
ripplesouth
laptop scan tool setup
Are you referring to http://www.graphics.cornell.edu/~v/b10scan/
? Is that what you used ?
DLC
Post by DLC »
That's precisely what I used on my 1993 Legacy Touring Wagon before I sold it some three and a half years ago. I also used it on another Touring Wagon to help diagnose a problem.
Legacy Central
ripplesouth
Is there anyway to get the scan tool software used in the juicebox ported over to a laptop or PocketPC, and use it with http://www.graphics.cornell.edu/~v/b10scan/
I figure my laptop or pocketpc would be less likely to break down, and both come with a 3 year warranty from HP
ripplesouth
Saskatoon Subaru
Post by Saskatoon Subaru »
sounds like you have to wire right into the ecu, doesn't sound like such a great idea to me anyway.
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
Saskatoon Subaru
i know this is a old thread but i figure i'd give this scan tool a try. just have a few questions.
1st(I Solved this one myself, somewhat but it left me with a diff problem if you look close enough it's stamped on the plastic) but mine looks like this
you have to pin layouts for the stereo harness
which is right?
2nd
since my laptop doesn't have a serial or parallel port could a use a usb to parallel adaptor?
if not i'll by a old $50 laptop for this, thanks
Both pin numberings I gave are right; they're looking at different ends of the connector.
If there are numbers stamped on your connector, they're not the same as Subaru's numbering.
If you're in any doubt, use the numbers I give and match up the wire colors I give.
You cannot use a USB-to-parallel adaptor.
Saskatoon Subaru
thanks for the info, now to get the laptop.
Boostedballs
Post by Boostedballs »
I tried the version 5 and the version 6 on my 91SS 4eat and I keep getting the message: "parallel port at 0378" "reading ROM ID..."
I'll keep reading about it.
Air-to-Water Intercooler, VF-39, 550 injectors, AEM FIC, stainless race header, 3" stainless exhaust, 75hp Nitrous, 150psi H2O injection, intake mods, stock: long block, 4EAT, ecm.
Boostedballs
I noticed some water damage on the port on my old Compac laptop. I think must have tried to flush that sucker down the toilet or something. I can't say I blame them either!
I'll get an extension cord run out to my car and use my newer toshiba portege with the docking station parallel port. I'll update...
Boostedballs
Dangit, my newer laptop has XP and I can't seem to get the scan tool to open properly on it. crap. I'm gunna go back to working on my water/alky injection setup for now...
Are you trying to burn the CD image? My guess is that you're burning it to a disc just as a file instead of as the entire disc image. Maybe someone here who uses XP can help you get that right.
TheSubaruJunkie
Post by TheSubaruJunkie »
The scan tool will not open in XP. XP does not have DOS, it has a NT Based Command Prompt, which is nothing like DOS and when trying to run the scan tool, it just wont work.
Boosted, you need to build a DOS Boot Disk, and load the scan tool from that. Win98SE has a boot disk maker. Or you maybe able to find a generic dos boot disk somewhere on the internet. Im not sure how to build a bootable CD from scratch, i know Nero has some options to do it, however you need to have specific files available to burn as well in order to boot to the OS.
Isnt there an .iso of a bootable image on VRGs website?
1983 Subaru GL-10 Brat
1986 Toyota 4Runner
iiigoiii
Post by iiigoiii »
i just wanted to say thanks again to vikash for writing this tool, and especially for posting it as open source. things like this are the truest spirit of community on the net...seriously!
one question for anyone here - has anyone compiled info on what these parameters are and what values they should be at different conditions (engine off, cold & warm idle, revving, under load, full boost, etc.)? i know some can be had from the service manuals, but they're mostly engine off and idle.
knowing what they should be for a well maintained and well tuned engine would be invaluable.
-bc
(ps. so what is the "load" parameter anyway?!?!)
dzx
Post by dzx »
Boostedballs wrote:I tried the version 5 and the version 6 on my 91SS 4eat and I keep getting the message: "parallel port at 0378" "reading ROM ID..."
I've been getting the same thing. I put a voltmeter on the wires and they're getting signal but apparently the computer isn't reading it. I'm using a Dos boot disk since my computer has windows xp.
Read the last page, I guess i'll try version .5 and see if it works.
///M
'93 Legacy SS - part out
dzx
Post by dzx »
and the older version worked right away....
///M
Soul Shinobi
Post by Soul Shinobi »
Vikash, after seeing your awesome Juice Box scan tool, I was wondering if you'd consider updating this computer based software for the poorer of us. I don't expect the awesome crazy graphs, but at least adding the trouble code readout and clear functions would make for a sweet update; the graphs would just be icing on the cake. :-D I hope such an update would be possible without having to add wires to the setup...
-Nick
1992 BC Legacy L Sedan AWD 5MT 272,000 - Wish you the best
1998 BK Legacy L Wagon 5MT 234,000 miles - RIP
2002 SF Forester S Wagon 5MT 215,000 miles - Current winter sleigh
1986 FC Mazda RX-7 GXL Coupe 5MT 155,000 miles - Summer cruiser
Humanzee
Post by Humanzee »
Looks like I got to the party late, The links and images in this thread are for the most part dead. Is there somewhere else I can get a hold of the software?
'93 SS Turbo
'90 L SW drove it into the ground now its dead and gone.
other:'00 A4 1.8t, 02 A6 3.0 Avant
Yeah,
I'm trying to mirror Vikash's old site. You can probably find it in the mean time via the internet archive.
Humanzee
Post by Humanzee »
Ok I found the write up on
http://web.archive.org/web/200710180401 ... v/b10scan/ however its dated back to October '07 . The only copy of the iso I could find there was dated back to February 19 2007. Is this the current version?
'93 SS Turbo
yes, it hasn't changed in a long while.
Im looking for the software too, as soon as you get everything squared away can you let me know?
biggreen96
Post by biggreen96 »
Does anybody have a copy of the version 5 scantool. I'm not getting the version 6 to work...
