Anybody know what this is?
monty's legacy
Post by monty's legacy »
So I popped my hood this afternoon to check my oil (have had a small leak for a bit nothing serious though) and I see this what appears to be some sort of a gasket lying between the drivers side fuel injectors.
It is approximately 2" across by 1/4" wide by 1/8" thick
After I found it I checked for any new fluid leaks and looked around and couldn't find anything remotely like it. I started the car and let it idle, nothing wrong there. Drove it home, more gingerly than normal but again no issues. Anybody have any clue as to what it is? I got to my mechanics a few minutes after he closed. Thanks again guys.
91 Lsi 180k RIP(3-19-06) Sold for $120
93 L 134ish, Bring on the Snow Baby
jake15
Post by jake15 »
That is the gasket that goes underneath the oil cap, if you turn your oil cap over you will notice a channel that looks very empty :-)
monty's legacy
jake15 wrote:That is the gasket that goes underneath the oil cap, if you turn your oil cap over you will notice a channel that looks very empty :-)
Thanks man, I had briefly thought of turning it over to check but decided nah couldn't be that. Thanks a lot man.
P.s. this site rocks
