Blinking CHECK ENGINE light after reading codes
schspeedster
Post by schspeedster »
After connecting connectors under the dash to read codes, the CEL blinks on & off continuously while running & driving. Both connectors are disconnected.
Have tried to reset the ECU by disconnecting negative from battery overnight, starting & idling 15 mins without touching accelerator, then shutting off. Still seems to run OK but CEL blinks contantly.
Codes obtained with black connectors connected:
11 - crank sensor
13 - cam sensor
31 - throttle
http://www.legacycentral.org/library/li ... /codes.htm
Original problem is intermittent cold start problem, usually in 40-50F outside temp range. Cranks for several minutes sounds like its trying to start, weak or no spark. Odor of unburned fuel when it finally starts. Had problem since bought car 3 years ago. Got much worse recently. Changed coolant temp sensor, plugs & wires.
cjc
Post by cjc »
have you checked coil pack and igniter?
93 turbo legacy
97 legacy gt wagon (rip)
2000 legacy l (rip)
1990 legacy wagon
schspeedster
Seems to startup and run ok now, would a ignitor or coil failure cause the CEL to blink?
It shouldn't.
You positive the connectors are disconnected? If so, try pulling the EGI/TCU fuse, pretty sure it's fuse 14.
schspeedster
Besides disconnecting battery and pulling fuse, have connected and disconnected both green and black connectors. With all 4 combinations of green and black open & closed, the engine starts & runs OK with CEL blinking on & off.
Been thru the resets in http://www.surrealmirage.com/subaru/engine.html
At this point the check engine light should start to flash the all clear signal (steady 1/2 second interval flashes). At this point the ECU's memory is cleared
I would assume the all clear signal is supposed to go away on its own?
Does the computer have any non-volatile memory that persists after battery disconnect? Hopefully checking codes doesnt risk permanently damaging the ECU.
schspeedster wrote:Been thru the resets in http://www.surrealmirage.com/subaru/engine.html
You have to disconnect the connectors, but it sounds like you did this....correct?
schspeedster
Yes, both the green and black connectors are disconnected.
schspeedster
Used the relearn procedure of starting and idling 10-15 minutes without touching the gas pedal. Havent driven too many miles since. I wonder how many miles of driving or cycles from cold to operating temperature are necessary for the ECU to relearn the settings.
schspeedster
Went for a half hour drive with full range of speed and throttle position, the CEL flashes continuously. The POWER light that normally goes on at wide open throttle doesnt light.
There has to be another means of resetting the ECU that I have overlooked. Does it require reprogramming with Subaru Select Monitor? Never thought that connecting jumpers to check and clear codes risked permanent damage.
schspeedster
Sounds like something may be funky with your ECU.
The ECU's never supposed to blink the check engine light unless it's in test mode, read mode, or clear mode.
The way these two connectors work is that one end is connected to the ECU and the other end is connected to ground. Is it possible that one end of one of those connectors is touching something else under your dash that's grounded?
schspeedster
vrg3 wrote:The ECU's never supposed to blink the check engine light unless it's in test mode, read mode, or clear mode.
Good suggestion. Had to pull on the green connectors to get enough slack to connect them, will have to check for a wire up against a sharp metal edge.
Oh. Yeah, if you had to pull hard on them, it seems quite possible that the insulation may have been damaged.
The ends you want to investigate are the read mode connector with the red-with-black-stripe wire and the test mode connector with the orange wire. The other ends have black-with-red-stripe wires and they're the ground side.
schspeedster
Wires: OK
ECU: FAIL
Running good now with the ECU replaced.
schspeedster
Still starts and runs good. Thanks to all for the help!
BTW got a new Legacy 2.5i SE few weeks ago, and am selling the car: http://bbs.legacycentral.org/viewtopic.php?t=35329
Great! I wonder what happened to the ECU though. That's weird. Maybe it got zapped with static electricity or something?
bry
Re: Blinking CHECK ENGINE light after reading codes
Post by bry »
linda's '94 has started flashing the CEL continuously for no reason. runs like a top though....
