WTB Sidefeed Injectors
morgue
Post by morgue »
Looking for sidefeed injectors and rails for a 91 Leg N/A to SS Swap
Running t3/t4 turbo and walbro pump with smt6 piggy ecu ...
Which injectors in particular are you looking for?
I have a set of STi injectors if you're interested. You'd need to get a pair of rails from a 92-94 non-turbo to use them.
morgue
Post by morgue »
i have a n/a 91 leg - that im turning into ss
You said that already. You should try to be more specific.
So... which injectors are you looking for? Stock turbo injectors? Or some kind of upgrade?
Stock turbo injectors should fit the rails from a 91 non-turbo. And you should be able to get them cheap from Blackbart:
http://bbs.legacycentral.org/viewtopic.php?p=246934
If you want the STi injectors, please let me know soon. Someone else would like to buy them if you don't.
advansti
Post by advansti »
I actually have alot of the parts you might need. All parts from a '91 Legacy Sport Sedan w/150K
Turbo heads, intake manifold w/injectors, even a Forester XT TMIC etc.
Matt
'91 Legacy SS
EJ257, Ph.1 DOHC, TD05-18g, FMIC, PP6, V.8 STi 6spd, H&R coilovers, Spec C control arms... the list goes on.
http://s595.photobucket.com/albums/tt33/advansti/
Matt Anderson
Time to ride!
Post by 555BCTurbo »
advansti wrote:I actually have alot of the parts you might need. All parts from a '91 Legacy Sport Sedan w/150K
Turbo heads, intake manifold w/injectors, etc.
Matt
I've seen your car...it's pretty!
93Subadan
Post by 93Subadan »
vrg3 wrote:Which injectors in particular are you looking for?
Are those the sidefed 550 cc/min yellow ones? I might be interested, how much would you be asking for them?
dropdfocus
Post by dropdfocus »
vrg3 wrote:If you want the STi injectors, please let me know soon. Someone else would like to buy them if you don't.
Sorry, they are already spoken for if this guy does not want them.
Jason
White Out
Post by White Out »
I have a set of PE850's with clips and STi fuel rails w/ pressure regulator available. PM me if you are interested.
1987 Buick Grand National
2003 WRX Sportwagon - ej207/vf30
2004 STi - built motor/gt35r
