FOLLOWING ALL MY POSTS ON SLOW LEGACY , ERATIC BOOST ECT
TODAY I HAVE ANOTHER PROBLEM (THINK IVE BROUGHT A LEMON)
CHANGED THE OIL TODAY WITH CASTROL RS 10/60, READ LOT OF BITS ABOUT
IS SUPPOSE TO BE GOOD AND I DRIVE THE CAR QUITE HARD .
NOW THE TAPPETS RATTLE LIKE F... . THEY DID BEFOR BUT ONLY EVERY NOW
AND THEN , NOW ABOUT 2 OF THEM RATTLE IN CYCLES ,THEY RATTLE FOR
ABOUT 30 SECS THEN STOP FOR 30 SECS AND SO ON ,,, REALY ANNOYING
THE CARS GOT A FULL MAIN DEALER HISTORY AND NEVER MISSED A SERVICE
ITS DONE 105 K , IVE ONLY HAD IT 6 WEEKS AND ITS FALLING TO BITS ON
ME LUV IT Grrrrrr .?????? , never had these problems with my ae86
thanx again
ROB
Monitoring Service trial
http://us.click.yahoo.com/MDsVHB/bQ8CAA ... /XoTolB/TM
ANOTHER PROBLEM / OIL
Josh Colombo
You need to change it back to the standard weight oil. I'm assuming
when you say 10/60, you mean 10w-60. That's way to thick. You're most
likely not getting oil flowing to the lifters, and that's where your
tapping is coming from. If the engine calls for the same specs as US
versions for oil. I would run 10w-30 or 10w-40. Follow the owners
manual for oil weights. I would suggest getting some engine flush and
run it through then change the oil, and put the proper viscosity in.
Josh Colombo
jcc189@psu.edu
of beats and rhythm" - ME
-----Original Message-----
From: rob440@hotmail.com [mailto:rob440@hotmail.com]
Sent: Saturday, September 01, 2001 6:52 PM
Subject: [BC-BFLegacyWorks] ANOTHER PROBLEM / OIL
TODAY I HAVE ANOTHER PROBLEM (THINK IVE BROUGHT A LEMON) CHANGED THE OIL
ABOUT 30 SECS THEN STOP FOR 30 SECS AND SO ON ,,, REALY ANNOYING THE
thanx again
ROB
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Josh Colombo
jcc189@psu.edu
thanx again
ROB
dfullerton
i had a different experience had the tapping lifter problem on and of since
i had the car, only used castrol magnex as recommened by subaru UK, change
oil and flush and noise goes away and the comes back when oil gets dirty.
Changed to Mobile one motorsport and the engine is quite and tapping noise
dose not come back 10-50 i think
----- Original Message -----
To: <BC-BFLegacyWorks@yahoogroups.com>
Sent: Sunday, September 02, 2001 5:40 AM
Subject: RE: [BC-BFLegacyWorks] ANOTHER PROBLEM / OIL
> Josh
> Josh Colombo
> jcc189@psu.edu
> thanx again
> ROB
> Josh
> Josh Colombo
> jcc189@psu.edu
> thanx again
> ROB
rob440@hotmail.com
thanx for all your help
rob
rob
rob440@hotmail.com
rob
rob
rob440@hotmail.com
CONFUSED NOW READ LOTS ON USING RS 10 W 60 SUPPOSE TO BE THE DOGS
PARTS ALSO MOTUL 15/50 N MOBILE 1 10 /50 OPPOSED TO THINNER OILS IE
5/30 ,,10 /30 ECT. SUPPOSE ITS DOWN TO PERSONEL TASTE AND
EXPERIENCE , IM GONNA DRAIN ALL £40 WORTH AND CREOSOTE THE SHED WITH
IT , THEN TRY SOMETHINK ELSE A BIT THINNER I THINK
THANX ALL
ROB
of since
change
dirty.
tapping noise
> From: "Josh Colombo" <jcc189@p...>
> To: <BC-BFLegacyWorks@y...>
assuming
You're most
your
as US
owners
flush and
in.
> > Josh
> > Josh Colombo
> > jcc189@p...
> > From: rob440@h... [mailto:rob440@h...]
> > To: BC-BFLegacyWorks@y...
THE OIL
NOW
THE
ON
ae86
> > thanx again
> > ROB
THANX ALL
ROB
of since
change
dirty.
tapping noise
assuming
You're most
your
as US
owners
flush and
in.
> > Josh
> > Josh Colombo
> > jcc189@p...
THE OIL
NOW
THE
ON
ae86
> > thanx again
> > ROB
