First a note on the stock turbo, MBC is set at 15psi, full boost by 3000rpm and it will hold that tell about 4500, after that it slowly drops to about 9psi at redline (6500). Seems the factory picked the smallest turbo that would hold designed boost at redline, which means the quickest spool… well engineered.
With the stock 370 injectors I had an AFR of 13:1 from 0 to 4psi then jumped to about 12:1 with a slow drop in the last 2000rpm to about 11.5:1 at redline. I would really like to see the whole range shift down 1/2 to 1 point. So yesterday in go the 440s, now the 0-4psi is at 12:1 then that jump is to 10:1, dropping to about 9.8:1 at redline. I guess I shouldn't be surprised, this is just about what I calculated with a 20% increase in flow. On full boosting pulls I could feel a bit of bogging from the overfueling. The stock ECU trimmed the idle and cruise back to stroich quite well. This morning on the way into work it seemed the whole range of AFRs was up by about 1/2 a point, so maybe I’ll leave the 440s in for a few days and see what shakes out.
Question, can the stock ECU trim the whole fuel range? I assumed it would only trim in closed loop and leave the rest to the stock mapping. Can it use the trim required to adjust the CL to move the OL map?
If the 440s don’t trim back a bit more I think I’m going back to the 370s and I’ll up the fuel pressure a bit to get the 10% or so I’m looking for. I like to see about 12.5:1 in the transition and 11.5-11.0 under high load.
Once I finish my stroker build/V24 I’m sure I’ll need the 440s if not 550s, I figure at that point a piggyback is my only choice.
Comments, ides or suggestions?
Gary
P.S. the 15psi hits like a hammer in 1st & 2ed gear.
