A friend from the USMB found these gadgets. Its a small display you wire in a temp sensor, and it just reads off the temperature. He uses it for EGT, i want to use it for Intake Temps. I would like to monitor the temp of the air leaving my intercooler, and this is a cheap and easy way to do so.
eBAY Link for Sensor & Display
Reading up on this, i found that you can also program it to alert you at a specific temperature. It will trigger an alarm, and even close a circuit when triggered
I found a decent size water tank at work. Looks like it will hold a gallon or two, so I set off locating the rest of the stuff I would need to plumb in the intercooler spray. After talking to a few, it seems the most important part of the sprayer is the nozzles being used, that they must create a fine mist in order for it to work propperly.
I came across this on the bay of E
I'll be updating this thread as the progress continues. Ordered the nozzles yesterday and the EGT monitor today, so it will be a week or so before I have all the parts I need.
-Brian
