90* inlet TD04 swapped for a 90* TD05-16G (now with pics!)
BXSS
Post by BXSS »
Got the EL headers & ported 16G on my 4eat SS yesterday.
General impression is no more boxer sound, slightly slower spool (noticeable), no boost spikes, & noticeably better top-end than the TD04@14psi at TD05 boost levels of just 11psi.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
dscoobydoo
Post by dscoobydoo »
Equal length headers and twin scroll set-ups tend to reduce the boxer sound.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
the_watts10
Post by the_watts10 »
is the td05 setup (pluming, intake and vaccum lines) the same as the td04? and will my stock internals withstand a Td05? (motor is completely rebuilt)
ej22t hybrid, 3.5" downpipe, Gl turbo intake/desnorkel 9psi DEAD
asc_up
Post by asc_up »
Yes and yes.
Search.
BXSS
Post by BXSS »
The JDM 90* inlet TD04 has the same 90* rubber elbow as the 90* inlet TD05 which is slightly different than the ej22t elbow.
I was not sure if the elbow had to be changed so I had a TD05 one ready for use just in case.
The rest of the intake pluming going toward the airbox is the same as a ej22t.
I actually took some pics of the TD04 & my spare TD05 side by side & the saw that the compressor housings were similar in size (TD04 was slightly smaller), but the TD04's turbine wheel was much smaller thant the 16G's.
? 18psi max safe boost on a EJ20G if fueling is OK...
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
BXSS
Post by BXSS »
Boxer sound is totally gone which is OK with me....
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
James614
Post by James614 »
No boxer sound = :(, but if it hauls enough ass then that's all that matters :)
the_watts10
boxer sound
well did the boxer sound go away because of the turbo or do you have equal length headers?
asc_up
Post by asc_up »
He has a EL headers and I believe a twin-scroll turbo which also gets rid of the boxer sound.
BXSS
Post by BXSS »
+1 EL headers got rid of the sound.
These headers have a double up-pipe but are not twin-scroll as the U/P from the left & U/P from right side of the motor merge right before the turbo - basically a "Y".
My 2.2E Phase II Impreza OBS-T never had the boxer sound as the factory "y" pipe is supposed to be equal length.
I think SubaruNation is going to post the TD05 & TD04 side by side comparison pictures.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
Post by SubaruNation »
going up now...
BXSS
Post by BXSS »
TD04 is on the left side of all the pics.
Thanks SubaruNation for posting the pics up for me!!
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
ya no problem :D
anybody have a bypass valve?
know1
Post by know1 »
are you selling the td04?
BXSS
Post by BXSS »
I'm not going to sell the TD04 just yet.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
biggreen96
Post by biggreen96 »
looks nice. What boost level are you going to run?
BXSS
Post by BXSS »
Thanks, I lucked out with these turbos & they are in good condition.
Just be careful that the e-housing is not cracked when you buy a JDM 16G (Look @ the pics of the turbos upside down & you can see were my buddy TIG'd the e-housing of my 16G).
They tend to crack in the same exact place (I got 2 that were cracked in the location shown).
I plan on running wastegate pressure for day-day scooting around which looks to be 8psi, & if I leave the EVC-EZ on the car high boost will be 15psi.
If I put the OLD school EVC-II on the car I'll run 8psi base boost, 10psi-lo, 12-13psi-med, 15-17psi-hi (drag-race 1-pass mode) depending on EGT level.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
BXSS
Post by BXSS »
UPDATE,
EGTs look OK, but spool seems too slow with the el headers.
The car is hitting 15psi @ about 37-3800rpm off a idle start (750rpm) & starts to build boost @ about 16-1700rpm.
Once the 4eat does spool the turbo it holds a steady 15psi as long as you hold the car @ WOT - no spikes, taper, or creep.
Based on the G-tech the car is .25 slower to 60MPH than the TDO4 @ 15psi, but is .6 quicker than the TD04 to 75MPH.
Max Acc G-force is recorded 1 second slower than it was on the TD04 - slow spool....
I expect 1/4mile times to improve vs the TD04 (76MPH 1/8th MPH on the track) based on the top-end improvments, but would like some of the low end response back.
I'm thinking of trying the OEM Turbo Manifold to see how it compares the to EL headers, I'm just really lazy & do not feel like getting into that install again.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
the_watts10
would you sell the td04?
BXSS wrote:I'm not going to sell the TD04 just yet.
BXSS
Post by BXSS »
I bad mouthed the headers too soon, it seems that 4000rpm is about right for max boost on a 16G/EJ20G or EJ205 based on friends with this turbo.
Which means max boost @ 37-3800RPMs is not too bad for this turbo/engine combo.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
adema2626
Post by adema2626 »
Very informing thread. Iv noticed the same things. I hit max boost at about 4000 rpm with the 16g turbo on ej22t block/ej20g heads and UE headers. To bad i just fried mine today. Hopefully it will be rebuild able.
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
cartwheels
Post by cartwheels »
The zombie threads have risen! Run away while you still can!
1994 Legacy TW
1991 Legacy SS
1990 VW Vanagon Westfalia
race_to_live
Post by race_to_live »
anyone know the stock boost for the 02 td04?
-91ss, 250,000mi rebuilt, tmic, tdo4, agx's w/groundcontrol, f/r strut bars, rust
-83 gl wagon...350,000mi custom dents
-62 honda 55, (moped)
-74 Yamaha rd 350
