Thanks Rod,
I'm pretty sure I've NOW found the part that you are talking about!! That is
definitely not the part I replace and would explain why my engine light is
still on. Now I have one question for you. How the hell do you change the
Purge Solenoid Valve?????? "It's a bitch to get to" is an understatement!! I
don't know where to start!
Help
Fred
------------------( Forwarded letter 1 follows )--------------------
Date: Tue, 18 Sep 2001 0947 +1000
Sender: sentto-2208544-4486-@gcs.alias
Reply-To: BC-BFLegacyWorks@yahoogroups.com
Subject: Re: [BC-BFLegacyWorks] Need help to
Fred,
it sounds like you have changed the auxillary purge control valve.
Yhe purge control solenoid valve has a vacuum hose going to and from with an
electrical connection. It sits underneath the inlet manifold (left side
looking at the engine from the front of the car)
Follow the line from the charcoal canister, one goes to the aux purge valve,
one from the fuel tank and the third goes to the solenoid purge valve.
cheers, Rod ....in OZ
ps its a bitch to get to......
----- Original Message -----
To: <BC-BFLegacyWorks@yahoogroups.com>
Sent: Tuesday, September 18, 2001 4:19 AM
Subject: [BC-BFLegacyWorks] Need help to
> Hi Mark,
> I was wondering if you ur engine light came on telling you that ur purge
valve
> was bad. I have a '92 turbo and according to Subaru it's my purge valve
(this
> was over a year ago) causing the light. I seemed to be getting different
part
> #'s for the Canister Purge Valve from different dealers. I've now
recently
> replaced by myself what I thought was the Canister Purge Valve but the
light
> still won't go away? Is the purge valve electronic at all?? What I
replaced
> was a little round thing that has a hose that connects to the Canister.
It
> sounds like it's the same thing u changed. Did you get ur's figured out?
> Did ur light go off?? I disconnected the battery terminals multiple times
and
> the light comes back on sometimes immediately when I start it back up and
> other times a few minutes later.
> Can anyone help me with this? The light is just annoying the hell out of
me
> after a year plus of watching it!!!
> Fred
> To unsubscribe from this group, please send an email to:
> BC-BFLegacyWorks-unsubscribe@egroups.com
Need help
Samuel Barrett
Need help
I replaced mine right when I bought the car and I gave up on the
reinstallation of it. Currently it hangs loose in the approximate location I
removed it from. No problems with it yet.
-Sambo
-----Original Message-----
From: FREDERICK.WHITMORE@CN.CA [mailto:FREDERICK.WHITMORE@CN.CA]
Sent: Tuesday, September 18, 2001 10:47 AM
Thanks Rod,
is
I
Help
Fred
Fred,
> Hi Mark,
valve
(this
part
recently
light
replaced
It
and
me
> Fred
-Sambo
Thanks Rod,
is
I
Help
Fred
Fred,
> Hi Mark,
valve
(this
part
recently
light
replaced
It
and
me
> Fred
Rod
Need help
Fred,
i had to take the power steering unit out of the way to get to it. It is a
bit of a job. There will be some leakage of power steering fluid.
regards, Rod
Sent: Wednesday, September 19, 2001 3:47 AM
> Thanks Rod,
is
the
understatement!! I
> Help
> Fred
> From: Rod[melrod]@optusnet.com.au
> Fred,
an
valve,
> From: <FREDERICK.WHITMORE@CN.CA>
> > Hi Mark,
> valve
> (this
different
> part
> recently
> light
> replaced
> It
out?
times
> and
and
of
> me
> > Fred
> > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
regards, Rod
> Thanks Rod,
is
the
understatement!! I
> Help
> Fred
> Fred,
an
valve,
> > Hi Mark,
> valve
> (this
different
> part
> recently
> light
> replaced
> It
out?
times
> and
and
of
> me
> > Fred
yahoo@mintzer.com
Need help
I recently did it, and it wasn't too bad
There's only one screw holding it in. I got to it with a ¼ drive 12mm
deep socket with a 6" extension. You just pop off the electrical
connector and the two vacuum lines (remember which goes where).
When you put on the new one be careful to not loose the screw (I like
finger tightening first to make sure I don't strip anything).
Oh yeah, you probably want to do it when the engine is really cold,
otherwise you'll hand will get mad at you.
