transmission swap question
oooo
Post by oooo »
Hello all,
I currently have a 2nd generation legacy sedan and am looking into maybe getting a 1st generation legacy turbo wagon if i can find one, or a na wagon as a project. I want to lift it and put on at least 29 inch tires but change my gearing to keep the performance. My question is can a 4.44 auto transmission from a obd2 1996-1997 legacy outback be swapped for the auto transmission in the obd1 first gen wagons without causing any problems like check engine lights and stuff. I know they will physically bolt up but what about the sensors and tcu compatability. Will the outback auto tranny have the same sensors as the obd1 auto tranny and just have some extra sensors added for the obd2 stuff . Is it basically plug and play? If it is which transmission tcu would I use? I assume I would use the tcu from the first gen obd1 wagon. Any information would be greatly appreciated
Thanks in advance
Welcome.
I believe the 96-97 trans is still considered the phase 1 transmission. Look at the connectors coming off the transmission. If they are both rectangular in shape, they should work. The phase 2 transmissions have a slightly different plug. There was some talk about it a while back. You may want to search for phase 1 or 2 transmission and see what you find.
