Part #
Locked
FREDERICK.WHITMORE@CN.CA
Part #
Post by FREDERICK.WHITMORE@CN.CA »
Hmmmmmmmm
Does the part # end with "000" or "001"? I email Richard at auto zone and he
said "001" then Stuart emailed (look below) saying it's "000" and you first
said "000" but now say "001". Are both of these #'s the same thing anyways?
Fred
------------------( Forwarded letter 1 follows )--------------------
Date: Thu, 20 Sep 2001 166:58 -0700
Sender: sentto-2208544-4539-@gcs.alias
Reply-To: BC-BFLegacyWorks@yahoogroups.com
Subject: Re: [BC-BFLegacyWorks] Digest Number 403
>Message: 5
> Date: Wed, 19 Sep 2001 12:510 -0400
> From: FREDERICK.WHITMORE@CN.CA
>Subject: Re: SHORT THR
>Would you guys happen to have the part # of the STI Short Shift Kit for our
>car? My local dealer is trying to tell me that they don't even make one for
>my car! They said they only have one for the WRX.
>How much did the installation cost?
>thanks guys
>Fred
Part Number's
93-2001 IMPREZA PARTS
Part Name Part Number.. Quantity
22B Bolt Subaru 57728FA041 2
22B Bush B(L/Link) 20251AA050 1
22B Bushing Transverse Link Front ST2022044000 1
22B Bushing Transverse Link Rear ST2022044010 1
22B Clip Subaru 57728FA020 6
22B Fender 57110FA050 1
22B Fog Lamp Cover Set (LH and RH) S075580070 1 Set
22B Front Bumper Assembly S075580080 1
22B J Nut 57738KA000 2
22B Lateral Link Assy-F S075580140 1
22B Lateral Link Assy Rear RH S075580150 1
22B Lateral Link Assy Rear LH S075580160 1
22B License Plate Bracket S075580210 1
22B Pillow Ball Bushing 20252PA000 1
22B Seat Right Front 64101FA680 1
22B Seat Left Front 64101FA690 1
22B Seat Rear Cushion 64401FA410 1
22B Seat Rear Seatback 64451FA810 1
Aero Splash Front Set J1017FA012 1 Set
Aero Splash Rear Set J1017FA015 1 Set
Air Filtration Kit G3210FC000 1
Air Intake Fender Plug (As Found On 00-01 RS) 46059FA000 1
Aluminum Control Arm RH 20200FA060 1
Aluminum Control Arm LH 20200FA070 1
Aluminum Control Arm Attaching Links 20217FA101 1 Pair
Aluminum Engine Hood 57220FA130 1
Alternator/Power Steering Tension Bolt 800508220 1
Alternator Tensioner Bolt 34435AA030 1
Alternator Tensioner Nut 34436AA000 1
Battery Warmer J6010FS000 1
Black Stars Front Grill Badge 91053FA000 1
Brakeline, Rear Disk RH (RS) 26531AA041 1
Brakeline, Rear Disk LH (RS) 26531AA070 1
Brakeline, Rear Drum(OBS and L) 26531AA020 1
Camber Adjustment Bolt, RS Front 20540AA090 1
Carbon Fiber Park Brake Handle (Manual Transmission Only) C1010FC121 1
Carbon Fiber RS Interior (Automatic Transmission Only) J1310FA130 1 Kit
Carbon Fiber RS Interior (Manual Transmission Only) J1310FA140 1 Kit
Carbon Fiber Shift Knob (Manual Transmission Only) C1010FC121 1
Carbon Fiber Strut Brace E4010FA100 1
Center Console Extension (Gray) J2010FC100ND 1
Clear Corner Lens (RH) 84451FA020 1
Clear Corner Lens (LH) 84451FA030 1
Door Lock Timer 88201FC030 1
EJ22T Turbo Longblock 10103AA310 1
Embroidered Impreza Trunk Mat J5010FS100 1
Engine Block Heater A0910AS000 1
Extended Arm Rest Beige J2010FA100GA 1
Extended Arm Rest Black J2010FA100OE 1
Extended Arm Rest Gray J2010FA100ND 1
FHI 18mm Sway Bar Rear 20450FA020 1
FHI 20mm Sway Bar Rear 20450FA040 1
FHI Sway Bar Bushings For 18mm And 20mm Bars 21047GA671 1 Pair
Forester Dual Cupholder (Dark Grey) 66150FC000OE 1
Forester Glovebox (Replaces Passenger Airbag With Modification) ST6600079000 1
Front Axle Housing (RH) 28012AC040 1
Front Axle Housing (LH) 28012AC050 1
Front Axle Oil Seal 28015AA07 1
Front Axle Oil Seal 28015AA021 1
Fuel Vapor Cannister 42036AC020 1
Gas Filler Area Drain Tube 09501J360 1
Gasket, Cylinder Head (SOHC engine) 11044AA521 1
Gasket, Exhaust Header (SOHC engine) 44022AA020 1
Gasket For Second Airbox MY99 RS 16553AA041 1
Gasket, Intake Manifold (SOHC engine) 14035AA382 1
Gauge Pack (Gray, Electronic) H5010FA001 1
Gauge Pack (Gray, 3 gauges) H5010FA034 1
Gauge Pack Housing (Gray) H0017FC910OE 1
Headlamp Washer Nozzle 86636FA040 1
Headlamp Washer Switch 83013TA000 1
Headlamp Washer T Valve 786634010 1
Impreza RS Full Front End Cover M0010FS140 1
Impreza RS Hood Cover Only M0010FS111 1
Impreza 2.5RS Logo Floormats J5010FS001OE 1 Kit of 4
Impreza RS Performance Muffler And Intermediate Pipe Kit SOA8377500 1 Set
Impreza Sedan and Coupe Spoiler - Aegean Blue E721FS000AB 1
Impreza Sedan and Coupe Spoiler - Brilliant Red E721FS000BR 1
Impreza Sedan and Coupe Spoiler - Caribbean Green E721FS000CG 1
Impreza Sedan and Coupe Spoiler- Crimson Pearl E721FS000CP 1
Impreza Sedan and Coupe Spoiler - White E721FS000GW 1
Impreza Technical Overview Kit MSA5AV140K 1 Kit
Impreza Pre Delivery Inspection Kit MSA5AV139K 1 Kit
Inner Fender Plastic Wheel Arch (RH) 59110FA000 1
Inner Fender Plastic Wheel Arch (LH) 59110FA010 1
Internal Trunk Release Handle X5751FA000 1
Key Blanks 57430AA140 1
Keyless Entry Upgrade H7110FS101 1
Legacy Turbo Crossmember 200100AA120 1
License Plate Lamp Housing 84301FA000 1
Lightweight Bumper Beam Front 57760FA400 1
Lightweight Bumper Beam Rear 57760FA192 1
Locking Gas Door (Flat Door) 57601FA000 1
Locking Gas Door Cable 57330FA030 1
Locking Gas Door "Fuel" Tab 57346AA010ML 1
Locking Gas Door Spring 57651FA000 1
Locking Gas Door "Trunk" Tab 57346AA000ML 1
Lugnuts, Chrome OEM (RS) 623006021 1 Set
Main Body Wiring Harness Front 81222FA030 1
Mudflaps (front will not fit RS) J1010FA200 1 Kit of 4
Nut-clips To Mount Splash Guards/Rear Spats/Mudflaps 91086AA000 2
NGK BKR6E-11 Spark Plug 22401AA310 1
Outback Sport Struts (Front RH) 20360FA360 1
Outback Sport Struts (Front LH) 20360FA370 1
Outback Sport Struts (Rear RH) 20310FA860 1
Outback Sport Struts (Rear LH) 20310FA870 1
Oil Cooler Kit Cover Cp Thermo 11054AA010 1
Oil Cooler Kit Hose 805918010 1
Oil Cooler Kit Hose 807611090 1
Oil Cooler Kit Oil Cooler 21311AA010 1
Oil Cooler Kit Oil Cooler Connector 21317AA021 1
Oil Cooler Kit Oil Cooler Pipe 21328AA040 1
Oil Cooler Kit PCV Connector 21369AA040 1
Oil Cooler Kit PT650297 Hose 807611031 1
Oil Union Threaded Nut (Oil Filter Screws Onto This) 15018AA021 1
Oxygen Sensor, RS Front (1998) 22641AA011 1
Oxygen Sensor, RS Front (1999-2001) 22791AA00A 1
Oxygen Sensor, RS Rear (1998) 22690AA420 1
P1 Front Spring 20330FA160 1
P1 Rear Spring 20380FA450 1
P1 Front Left Strut 20311FA960 1
P1 Front Right Strut 20311FA950 1
P1 Rear Left Strut 20360FA960 1
P1 Rear Right Strut 20360FA950 1
P1 Front Grill 91065FA200NN 1
P1 Steering Wheel (STI) 34311AE200 1
P1 Front Right Seat Back Rest 64152FA740MU 1
P1 Front Left Seat Back Rest 64152FA750MU 1
P1 Front Left Seat Cushion 64142FA750MU 1
P1 Front Right Seat Cushion 64142FA740MU 1
Plastic Pop "Rivets" 57728AC090 1
Plastic "Screw" Rivets 794070240 1
Power Antenna 86321FA030 1
Radio DIN Pocket 66128AE000 1
Rear Bumper Cover E7710FS000 1
Rear Differential Protector B0310AS002 1
Rear Fog Lamp Switch (Eurospec Cars) 83001FC061 1
Rear Spats (Underspoiler) Full Kit With All Hardware X5771FA000 1 Kit
Rear Spat (LH Side Single Spat) 57796FA030 1
Rear Spat (RH Side Single Spat) 57796FA020 1
Rear Spat Protector Strip RH (The Rubber Trim Strip) 96054FA140 1
Rear Spat Protector Strip LH (The Rubber Trim Strip) 96054FA150 1
Rear Spat Threaded Mounting Plate 57790FA080 1 Pair
Rear Wiper Arm Assembly (Japan Spec) 86532AA000 1
Rear Wiper Arm Cover (Japan Spec) 86538GA080 1
Rear Wiper Blade Assembly (Japan Spec) 86542AA000 1
RS Bulkhead Wiring Loom (1999-2001) 81322FA100 1
RS Brake Booster (1998 Model Year) 26401FA030 1
RS Clutch Cover (1999-2001) 30210AA411 1
RS Clutch Disk (1999-2001) 30100AA690 1
RS Clutch Flywheel (1999-2001) 12342AA000 1
RS Clutch Gasket (1999-2001) 44022AA020 1
RS Clutch Radial Bearing (1999-2001) 30502AA051 1
RS Engine Hood 57220FA090 1
RS Engine Mounts RH 41022AA080 1
RS Engine Mounts LH 41022AA090 1
RS Fog Light RH 84501FA380 1
RS Fog Light LH 84501FA390 1
RS Fog Light Bracket (RH) 84927FA001 1
RS Fog Light Bracket (LH) 84927FA011 1
RS Fog Light Cover (RH 99-01) 57744FA220SJ 1
RS Fog Light Cover (LH 99-01) 57744FA230SJ 1
RS Front Brake Pads 26296FA100 1 Pair
RS Front Brake Caliper (RH) 26291FA050 1
RS Front Brake Caliper (LH) 26291FA060 1
RS Brake Caliper Pins (Need 4) 26228FA000 1
RS Brake Disc Shield (RH) 26290AC100 1
RS Brake Disc Shield (LH) 26290AC110 1
RS Front Bumper Inner Beam (00-01) 57760FA500 1
RS Front Bumper Beam (US 98 and Canada) 57760FA002 1
RS Front Bumper Vent (RH) 57744FA200 1
RS Front Bumper Vent (LH) 57744FA210 1
RS Front Bumper Skin (US 00-01) 57720FA280 1
RS Front Bumper Skin (US 98 and Canada) 57720FA160 1
RS Front Bumper Turn Signal (RH 99-01) 84441FA160 1
RS Front Bumper Turn Signal (LH 99-01) 84441FA170 1
RS Handbrake Assembly RH 26051FA140 1
RS Handbrake Assembly LH 26051FA150 1
RS Headlight (RH 99-01) 84001FA441 1
RS Headlight (LH 99-01) 84001FA451 1
RS PCV Valve 11810AA000 1
RS Rear Bumper Cover 57720FA032 1
RS Sideskirt Clip (Need 14 For New Install) 91167AA110 1
RS Sideskirt Clip (Need 6 For New Install) 91167AA000 1
RS Sideskirt Clip (Need 2 For New Install) 96058FA100 1
RS Sideskirt Front Right 96053FA000 1
RS Sideskirt Front Left 96053FA010 1
RS Sideskirt Rear Right 96053FA020 1
RS Sideskirt Rear Left 96053FA030 1
RS Sideskirt Protector Front Right (The Rubber Trim Strip) 96054FA120 1
RS Sideskirt Protector Front Left (The Rubber Trim Strip) 96054FA130 1
RS Stock Corner Lens (RH) 84401FA040 1
RS Stock Corner Lens (LH) 84401FA050 1
RS Stock Wheel (2000-2001) 28111FA270 1
Security System Upgrade (1998-2001) H7110FS201 1
Shifter: Nut 023508000 1
Shifter: Stock Shifter Bushings 35035AC030 1
Shifter: Washer/Plate 35017AA002 1
Short Throw Shifter Kit (SPT) C1010FA000 1
Sideview Mirror Glass (Right Side) 91039FC040 1
Sideview Mirror Glass (Left Side) 91039FC050 1
Single Stage Brake Booster 26402FA071 1
Single Stage Brake Booster Master Cylinder 26401AA231 1
Skidplate, Front SCI600036 1
Steel Take-Off Wheels 28111AC100TO 1
Steering Wheel Mounted Boost Gauge H5010FA032 1
STi Engine Mounts RH ST4100055110 1
STi Engine Mounts LH ST4100055120 1
STi Foglamp Cover Mounting Hardware ST5771155000 1
STi Front Strut Tower Bar (Non Carbon-Fiber) ST2050055040 1
STi Gas Cap ST4203355000 1
STi Strut Hats Front ST2031055000 1
STi Strut Hats Rear RH ST203704S000 1
STi Strut Hats Rear LH ST203704S010 1
STi Rear Differential Bushing Front ST4130055000 1
STi Rear Differential Bushing Rear ST4130044000 1 Set
STi Rear Strut Tower Bar (Sedan/Coupe) ST2050055030 1
STi Rear Strut Tower Bar (Wagon) ST2050055020 1
STi Stainless Steel Door Sills (Sedan, Front Pair Only) E1017FA003 1 Pair
STi Stainless Steel Door Sills (Sedan, Full Set) E1017FA002 4 Pieces
STi Stainless Steel Pedal Set Chrome (Manual Transmission) E1017FA002 4 Pieces
STi Tach/Speedo Cluster (Tach in Center) ST8100055230 1
STi Transmission Mounts 41022FA080 1
STi Two Pot Brake Adjuster Assembly (Need 4 For New Install) 26258AA020 1
STi Two Pot Backing Plate (LH) 26655FA030 1
STi Two Pot Brake Caliper Pin (Need 4 For New Install) 26267AA010 1
STi Two Pot Brake Caliper (RH) 26692FA000 1
STi Two Pot Brake Caliper (LH) 26692FA010 1
STi Two Pot Brake Shoe Hold Down (Need 4 For New Install) 26267AA010 1
STi Two Pot Brake Lever (RH) 26259PA000 1
STi Two Pot Brake Lever (LH) 26259PA010 1
STi Two Pot Brake Pad Clips (Need 2 For New Install) 26232AA040 1
STi Two Pot Parking Brake Shoe Disc 26298AA020 1
STi Two Pot Brake Plate (Need 2 For New Install) 26268PA000 1
STi Two Pot Brake Rotor (Need 2 For New Install) 26710FA130 1
STi Two Pot Brake Spring Adjuster (Need 2 For New Install) 26265AA071 1
STi Two Pot Brake Shoe (Need 4 For New Install) 26265AA040 1
STi Two Pot Brake Spring (Need 2 For New Install) 26267AA010 1
STi Two Pot Brake Spring Washer (Need 2 For New Install) 625303000 1
STi Gold Electra Rims ST2810079000 1
STi Strut Hat Complete Front ST2031055000 1
STi Strut Hat Complete Rear ST2032044140 1
STi Version 4 Wiring Loom 81403FA211 1
STi Version 5/6 Foglamp Cover RH 57744FA220SJ 1
STi Version 5/6 Foglamp Cover LH 57744FA230SJ 1
STi Version 6 Front Lip Spoiler 57796FA530NN 1
STi Version 5/6 Rear Bumper Cover 57720FA132 1
Subaru Parts Reference Guide (1985-2000) MSA6P0005 1
Subaru Strut Tower Brace E4010FA000 1
Swaybar Endlink Bolt And Washer 901250054 1
Swaybar Endlink Nut 902350001 1
SWRT Rally Blue Mudflaps Front ST9601055100 1 Set
SWRT Rally Blue Mudflaps Rear ST9601055110 1 Set
Tail Combination Lens (Red/Clear) RH 84201FA180 1
Tail Combination Lens (Red/Clear) LH 84201FA190 1
Timing Belt Tensioner 13033AA002 1
Toolkit (MY00) 97010AA050 1
Trunk Light 84611GA000 1
Trunk Light Striker Plate Assembly 57531FA000 1
Trunk Net F5510FS000 1
Wheel Locks T3010YS010 1 Set Of 4
WRC "SWRT" Shift Knob ST3502255000 1
WRX Brake Caliper Bracket 26225AE000 1
WRX Brake Rotor 26310AC040 1
WRX Vented Brake Duct Mud Guards (RH) 59110FA061 1
WRX Vented Brake Duct Mud Guards (LH) 59110FA061 1
WRX Vented Brake Duct Only (RH) 59110FA060 1
WRX Vented Brake Duct Only (LH) 59110FA070 1
Stuart Logan N7QYJ
slogan@mac.com
91' Legacy Turbo Sedan
98' Legacy GT Wagon
99' Impreza 2.5RS Turbo Coupe
Monitoring Service trial
http://us.click.yahoo.com/MDsVHB/bQ8CAA ... /XoTolB/TM
Locked
