Idle sky rocket after a hard run...
smh0101
Post by smh0101 »
So, after a semi-hard freeway run the idle launches itself up to about 3k.
Like, if I push in the clutch the rpm goes up to about 3-3.25k
Its kind of annoying. Any thoughts? Is the IAC valve sticking or something?
PhyrraM
Post by PhyrraM »
clutch switch, idle switch, or possibly a bad TPS?
Do you have a way of running Vikash's scan tool or even teh VWRX one?
smh0101
Post by smh0101 »
Not really...
I could try and replace the TPS with the one off my old engine... I suppose...
smh0101
Post by smh0101 »
Ya know... after I blip the throttle it goes back down to normal...
I'll try the tps
PhyrraM
Post by PhyrraM »
If you replace it you will probably need a digital multi meter to set it properly.
Safer to swap the whole throtlebody.
smh0101
Post by smh0101 »
Hrms... Okay... I suppose I could do that... How hard would that be?
Post by 555BCTurbo »
Just change the entire throttlebody...
Check for vacuum leaks too!
smh0101
Post by smh0101 »
555BCTurbo wrote: Check for vacuum leaks too!
I had enough of those!!!
Re-did a ton of vac lines to fix some...
There was one other issue... when I was up in the upper rpms in 4th gear it would cut like fuel cut then continue up the rev range.
Me redoing the coffee cup mod fixed that though... it had some thing to with it because it went away after that.
Metered air leak...
smh0101
Post by smh0101 »
Gotcha... I re-did it with brass fittings and lots of JB Weld and black paint to fix it.
smh0101 wrote:Gotcha... I re-did it with brass fittings and lots of JB Weld and black paint to fix it.
Ah yes...nothing like good ole' black paint to fix everything! :lol:
smh0101
Post by smh0101 »
hahaha... lol Yup!
Does look better though!
asc_up
Post by asc_up »
Hey! I painted mine black, too. So no hating...
If you blip it and it comes back its most likely the IAC valve. My car did that and sometimes low idle. Sprayed throttle body cleaner which was made for IAC valves as well (ones that don't say that are bad) or wd40 works as well.
smh0101
Post by smh0101 »
FIXED!
So after spraying the SHIT out of the IAC Valve... It didnt do a damn thing
So I replaced the throttle body...
Whalah! All is well now... and runs quite nicely I might add!
I won't even say it :D
smh0101
Post by smh0101 »
Say what? I must be too tired to get it...
smh0101 wrote:Say what? I must be too tired to get it...
That I was right lol
smh0101
Post by smh0101 »
Oh... Yeah... you and Phyrra were
I guess that means TPS was going bad?
Quite possibly...also, your throttlebody could have been getting stuck somehow
smh0101
Post by smh0101 »
The throttlebody seemed fine... It seemed to flip back to normal just fine...
Did your TB have the adjustment screw for the air bypass on the top of it?
http://www.main.experiencetherave.com/subaru/images/tb/
