Hit the dragstrip tonight
mattyg41383
Just got back from street night at Lebanon Valley Dragway (West Lebanon, NY ((near Albany)). Overall it was better than I was expecting.
'93 SS - auto - stock engine except for '98 legacy airbox + coffee cup.
15.969 @ 84.81
15.815 @ 84.68
15.759 @ 84.73
15.955 @ 84.69 (ran consecutive runs, engine hot)
15.783 @ 84.96
best 60' - 2.172
still well over a second slower than my '86 XT, but its a good start as far as Im concerned. Front mount is the next step.
15.969 @ 84.81
15.815 @ 84.68
15.759 @ 84.73
15.783 @ 84.96
best 60' - 2.172
-Matt
1993 Legacy SS - auto
1997 Impreza coupe
1986 XT - 14.5s @ 95mph
1990 Legacy wagon "the Red Dragon" -sold (300K miles and it lives on)
1997 Impreza coupe
mattyg41383
I wanted to get an IC going first, make sure things are ready to handle higher boost, i could always throw one of my saab ICs on top but i want to go front, so Im saving up. I'm definately going to be going with a bigger turbo, MBC, 3" exhaust, necessary fuel system changes, etc... I already have DOHC heads, i just need to polish/knife edge them. I'm on the college budget, so I cant do it all in one shot, ya know.
-Matt
1997 Impreza coupe
1997 Impreza coupe
if you are near albany, I require you to be at this rallyx on oct 1st
http://forums.nasioc.com/forums/showthread.php?t=961638
yo mang, can I get a rootshell?
1991 N/A, 4eat, crazy lights, junk suspension, sticker wagon
1989 xt6 work in progress
Innovative Tuning
farfrumwork
I was gonna say that for a, basically, stock auto the 60' is pretty damn good
and nice consistent times, the auto helps that for sure.
Let us know how it progresses
-Chad
-Chad
Old - '93 T-Leg - 14.693 @ 92.68 at 5800ft ASL (Bandimere Speedway)
New - 07 Spec B/stg 2
"bloodstains - speed kills -fast cars - cheap thrills -rich girls - fine wine
i've lost my sense - i've lost control - i've lost my mind" Agent Orange
mattyg41383
yeah, its an auto... if someone can get drastically better 60's with an auto and stock boost, I wanna know the tricks, lol.
I'm gonna check out that link and see if I have free time for that RallyX.
-Matt
1997 Impreza coupe
1997 Impreza coupe
BAC5.2
mattyg41383
I was M.I.A. for a while... As for how I launch: Line up shallow like usual so I can hit a consistant light, Stomp the brakes, get the boost up to the point where I almost push through the brakes, *third yellow* go. I shift the auto manually as well (if that makes sense).
As for the stoppers; I have EBC Sport Rotors (slotted + dimple drilled) with EBC Green Stuff pads., ABS removed, synthetic fluid.
The track is closed till April, so that sucks.
-Matt
1997 Impreza coupe
1997 Impreza coupe
mattyg41383
Funny thing with my car is that on the street with the TD04 on it would start to spin tires about 1.7 seconds after it was floored (full boost) & run 14.1 1/4s with no alky based on the G-tech, on the track there was 0 wheelspin & it ran 14.59 (14.69 on the G-tech for that pass) @ the same settings / same weak launch.
I'm thinking of using the 45*airbox on my car as you did because the stock MAF inlet is very close to the wall of the stock SS airbox & looks like it may be a bit of a restriction.
The 16G is on now so times should improve some.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
Boostedballs
I'm starting to think more about the stock MAF location after seeing your times. I am running a stock 90deg box but I'm running a water-to-air intercooler and water/meth injection and my times are 15.9 on a 90+ degree day. This is with a little bit of powerbraking on the 4EAT and stock boost.
I also have my snorkle cut out but I'm gunna go to the next step and do something about my air box. I'm even considering moving the airbox into the fender where the snorkle used to be. I even have a K&N filter in there!
nice times BTW.
nice times BTW.
Air-to-Water Intercooler, VF-39, 550 injectors, AEM FIC, stainless race header, 3" stainless exhaust, 75hp Nitrous, 150psi H2O injection, intake mods, stock: long block, 4EAT, ecm.
