White lithium grease Tub or Spray
doga501
Post by doga501 »
Hello Everyone
I'm about to reinstall my transmission after a clutch change I have a spray of white lithium grease and i was wondering if the the spray or the tub would make a any difference for the idler bearing release fork?
Thanx
You're probably better off using a high temp wheel bearing grease then white lithium
