what to do ??? control arm bolts-19mm ones
what huh
Post by what huh »
the threads are messed up inside the bolt hole which inturned ruined my bolts. I can't think of what to do . . .
Any Ideas?
1998 Legacy GT-T ... sold
n2x4
Post by n2x4 »
Can you weld?
This happened to me. I had enough thread that I could get it started in the hole and welded it in to be like a stud. I cut the head off the bolt and bought a nut. I welded the stud to the body and then screwed my nut onto the stud. 20K miles and it's still fine...
SUBARUEHS Racing
what huh
Post by what huh »
yeah i can weld, and my dad has a welder and that is a good idea
really good idea.
Hocrest
Post by Hocrest »
Not sure which bolt hole? the ones in the chassis?
You could get a tap of the proper size and fix the threads...
[size=75]-97 Legacy (ain't never gonna die)
-92 SVX (attention whore)
-86 Brat (more fun than the SVX)
-92 SVX Racer (lightest SVX)[/size]
jamal
Vendor
Vendor
Post by jamal »
I bought a helicoil. It's like $80 though for that size. I could mail it to you I guess but that would take a few days.
what huh
Post by what huh »
im going to try to tap it first. But if that doesn't work i will do the weld thing
