Compression Test
Compression Test
I want to do a compression test but need to crank the engine without fludding it. Do you know how to shut off the fuel pump (fuse,switch,etc.)?
94 Legacy wagon turbo
I would unplug the fuel injectors connectors and unplug the coil pack for safety as well. All in all it should be only 5 connectors. I'm not sure if there is a fuse for the fuel pump, but if there is it will most likely be located under the driverside dash, located on the left, near the hood latch.
It should me covered by a plastic cover that has carpeting on it, it just pops out.
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
