Top Hat Bolt Replacement?
Dynamic Entry
Post by Dynamic Entry »
I am one of the people that has caused jamal stress lately in repeating himself.... but at least i took his advice
So i got GC8 spec footwork to keep the geometry the same. It came from japan and is quite tidy except
anyone have experience replacing a bolt here? I am heading to The Bolt Supply House tomorrow to see what they say. It's got little splines on the inside of the hole....
Andrew
16 Outback - wife's daily
95 Gravel Express - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
ciper
Post by ciper »
If you can get a matching diameter bolt its not extremely important for it to be pressed in like the old one. The "ring" around the middle and gravity does most of the work hold the parts together.
Hocrest
Post by Hocrest »
But if it's not pressed in, you'll have a hell of a time keeping it from spinning when you tighten the nut.
But if you get a couple of weld spots to hold the bolt, you'll be golden.
[size=75]-97 Legacy (ain't never gonna die)
-92 SVX (attention whore)
-86 Brat (more fun than the SVX)
-92 SVX Racer (lightest SVX)[/size]
ciper
Post by ciper »
Threshld1
Post by Threshld1 »
Why dont you press a stud out of your/an old tophat and press it into this one?
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
Dynamic Entry
ciper wrote:Image
mmmmmm lockkkkkk washersssss
the internal star one looks aggressive, will look for one tomorrow
I bought a grade 8 5/16ths bolt today with a split washer. figuring maybe I can get a wrench on the bottom of the bolt while tightening down the nut....
we'll see if I have the gumption to try this tomorrow, but it might rain all day......
i have no welder/access to one right now.
i don't think I can push the stud in/out because of the wide head on one end and the threads on the other. to be honest I am quite mystified as to how these are assembled.....
Andrew
92 Green SVX - RIP
02 WRB WRX - Sold
ciper
Post by ciper »
Well if you had a stud on its own you could use the new nut to "pull" the stud into its new home.
I bet you could put two nuts tightened against each other on an old stud then use a hammer to bang it out.
Dynamic Entry
I will try this. after looking again i noticed that the splines are a tiny bit wider than the threads so the stud should push out
we'll see
Andrew
92 Green SVX - RIP
02 WRB WRX - Sold
Threshld1
Post by Threshld1 »
Yup, they are just a knurled press fit bolt. Same as how your lug bolts are attached. Get a BFH and go at it!
91 SS AT
n2x4
Post by n2x4 »
Be careful when you torque those down. They aren't the toughest things - I tightened one clean off once.
SUBARUEHS Racing
Dynamic Entry
ha ha ha, it took me a second to process BFH. I had huge flashbacks of running around shooting big green balls of death at pixelated zombies
but I will find a hammer
about the torqueing, I will see if my haynes says anything about it and/or be attentive about it. thanks!
Andrew
92 Green SVX - RIP
02 WRB WRX - Sold
ciper
Post by ciper »
BFG9000 ftw!
Dynamic Entry
No Clipping FTMFW!
Andrew
92 Green SVX - RIP
02 WRB WRX - Sold
ciper
Post by ciper »
LOL idspispopd
kleinkid
torque table
Post by kleinkid »
The Haynes manual will give you a torque value for the nuts on those studs. Just for general info here is chart for torque values for metric size fasteners.
http://www.tpub.com/content/filters/TM- ... 3P_105.htm
ciper
Post by ciper »
Nice link Kleinkid but where are the 14mm bolts? The chart seems to confirm my usual torque of 15ft lbs.
kleinkid
Post by kleinkid »
Torque values are always determined by thread dia. and /or material. Not by the size of wrench used.
Dynamic Entry
eh?
well, to bring this thread back on track: hamering a stud out of a top hat is the easiest thing Evar. And pulling it into a new one is lso easy with vice grips.
My STi suspension is in now and I have 11 extra top hat studs too. :)
Andrew
92 Green SVX - RIP
02 WRB WRX - Sold
