ecu reset.... which one do u disconnect... + or - i
unplugged the + ...does it matter?
Do You Yahoo!?
Make a great connection at Yahoo! Personals.
http://personals.yahoo.com
ecu reset
Mark Ward
ecu reset
I unplug the positive but it should not matter. You need to keep it
unplugged long enough for the computer to loose its memory. About 30 sec to
1 minute.
Mark
www.rrunracing.com
>Do You Yahoo!?
1 minute.
Mark
www.rrunracing.com
>Do You Yahoo!?
Josh Colombo
ecu reset
Mark, you need to keep it unplugged for longer then that. YOu need to keep it unplugged for 45-60 min.
As far as battery terminals to unplug. I'd recommend the negative terminal. All the manuals and books and such, always tell ya to disconnect the negative battery terminal, not the positive.
Josh Colombo
jcc189@psu.edu <mailto:jcc189@psu.edu>
of beats and rhythm" - ME
-----Original Message-----
Sent: Sunday, October 14, 2001 104 AM
Subject: Re: [BC-BFLegacyWorks] ecu reset
1 minute.
Mark
www.rrunracing.com
>Do You Yahoo!?
ADVERTISEMENT
<http://rd.yahoo.com/M=194081.1637497.31 ... ?code=3258>
<http://us.adserver.yahoo.com/l?M=194081 ... =754348574>
Josh Colombo
1 minute.
Mark
www.rrunracing.com
>Do You Yahoo!?
ADVERTISEMENT
Daniel Wilson
ecu reset
No you don't. People have just used that figure because it is easy
and will definately reset it. It will actually reset before 5 minutes.
The battery terminal thing, yes the negative is the best to remove
because when you replace the negative terminal you don't get spikes
in the electrical system like you would replacing the positive
terminal. Not that good for the electrics.
to
> Josh
> Josh Colombo
> jcc189@p... <mailto:jcc189@p...>
> From: Mark Ward [mailto:mark@r...]
> To: BC-BFLegacyWorks@y...
30 sec
> to
> 1 minute.
> Mark
> www.rrunracing.com
> >Do You Yahoo!?
> >Your use of Yahoo! Groups is subject to
FREE COLLEGE MONEY
CLICK HERE to search
600,000 scholarships!
http://us.click.yahoo.com/Pv4pGD/4m7CAA ... /XoTolB/TM
to
> Josh
> Josh Colombo
30 sec
> to
> 1 minute.
> Mark
> www.rrunracing.com
> >Do You Yahoo!?
FREE COLLEGE MONEY
Josh Colombo
ecu reset
I'll be damn.....ya learn something new every day.
Thanks Dan
Josh Colombo
From: Daniel Wilson [mailto:daniel.wilson@db.co.nz]
Sent: Sunday, October 14, 2001 2:36 PM
Subject: [BC-BFLegacyWorks] Re: ecu reset
to
> Josh
> Josh Colombo
30 sec
> to
> 1 minute.
> Mark
> www.rrunracing.com
> >Do You Yahoo!?
FREE COLLEGE MONEY
Thanks Dan
Josh Colombo
to
> Josh
> Josh Colombo
30 sec
> to
> 1 minute.
> Mark
> www.rrunracing.com
> >Do You Yahoo!?
FREE COLLEGE MONEY
