Made for the 1990-1999 Legacy Sedan only.
90-91models: might not fit unless the top hats are changed to the later, wider design
Brand new old stock.
(click for gallery)
TireRack info for 99 2.5GTFront and Rear fitment
Ride Height: Moderate Lowering
Note: Avg Low 1.25"F 1.0"R
Does not include Wagon. For 4 wheel drive models only.
Customer must measure rear springs to make sure the
H&R's are the same size. Some cars use a different
size spring in the rear and there is not a Sport Kit for those vehicles.
Rear HR spring dimensions:
Top outer diameter 160mm Top inner diameter 137mm
Bottom outer diameter 150mm Bottom inner diameter 125mm
Will fit wagon models but is designed for the sedans only.
$150 plus shipping.
