WRX turbo and turboback exhaust
Subiepoo11
Post by Subiepoo11 »
I have two questions. I have a 93 legacy turbo and I want to put a TD04 turbo in from a WRX, will that work and if so what will I need to do to make it work? Also I want to put in a turboback exhaust in and what exhaust would work for this car? :smt033
Post by SubaruNation »
td04 as far as i know is Plug and play.
and exhaust from anything will work if you have the right bends, it might have to avoid some things... differential and such.
i have 06 STi Exhaust and it required very little work, just an extention.
Subiepoo11
Thanks for your advice. I'm still going to look into it more before I do these mods.
ya i'd recommend the search button.... top right corner
smh0101
Post by smh0101 »
You need:
Way to overcome the different intake styles because WRXs and STis have an under the intake mani inlet... while Legacy Turbos have a 90* Elbow that comes up behing the runner.
Recommendation: 90* Silicone Elbow
And an Intercooler... the stock legacy turbo vf-11 has a 45* clocked outlet due to the lack of stock intercooler. The td04 has a 90* outlet. So you need an intercooler to mate to the turbo and the intercooler then mounts to the intake manifold.
Recommendation: 2006-2007 WRX TMIC (Or 2004+ Forester XT TMIC)
As for the exhaust... Use a WRX one... but it needs to be extended about 6 inches due to the extra length of the legacy.
And search is your friend.
Subiepoo11
I have a Saab intercooler on it and that works great. Would that still work?
93 SS 253K: 16g 550s 06 tmic 3'' tbe mbc custom intake rob tuned 16psi 5 speed swap H&R springs gr2's wrx wheels. 14.4 @ 94.4 mph at 5280.
07 STI 54k: Daily driver, stock for now.
smh0101
Post by smh0101 »
yup
yazmo
Post by yazmo »
smh0101 wrote:You need:
what year of the wrx exactly
