the TD05 is on!
92ss satinsvoice
the TD05 is on!
Post by 92ss satinsvoice »
so i got the turbo installed after some work and modifying some things. im running about 12psi with stock injectors, fuel pump and MAF.
now i just have to install my 565's, fuel pump and tune the pp6 at 18-20 psi. and see how see dose. :twisted:
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
know1
Post by know1 »
damn! nice! What are you using to cool? fmic, tmic?
94SS_Canada
Post by 94SS_Canada »
Post some pics and dyno results:D!
FastRust
Dynamic Entry
Post by Dynamic Entry »
+1 for pictuars
Andrew
16 Outback - wife's daily
95 Gravel Express - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
92ss satinsvoice
im running a frontmount intercooler. and i looked again while running my car and im only running like 10psi.
ill post pictures but ive got bad news.... i think i blew the turbo already but i cant really say. after i ran the car hard from 0-120 i let off and drove normal. i came up to a stop sign and i got a kinda big amount of smoke out from my hood. so i shut the car down and looked under the hood. i had oil on my intercooler pipe that loops around behind the turbo. i have a stripped nut on one of the bolts for the down pipe so theres a little bit of a gap. so i figured that i blew the rear seal and the oil shot out from the exhaust turbine. was able to get through the gap inbetween the downpipe and turbo to get on the charge pipe. its not coming from the top bango nut from what i can tell and oil is'nt spraying in the engine bay from the turbo while the engine is running so. while i was driving it home i was hearing a weird sound coming from the area of the turbo. it sounds kinda like a pipe draging on the ground or a pipe can. it might be the loose bolt and nut on the down pipe but i dunno. so tomarow im going to take the down pipe off and see if theres any shaft play. so i hope that i didnt blow it cause i just got it and it was a used jdm turbo.
Andy
94 L n/a 5spd, Rip
94SS_Canada
Always double Check everything!
Hope its not to bad.
GL
FastRust
asc_up
Post by asc_up »
Well before everything went crazy, how did 10 PSI on the TD05 compare to 14 PSI on the VF11? Noticeably faster?
92ss satinsvoice
oh god ya. it was a waaay smoother power curve and it pulled very nice, very comfortable type of power. not the type that will slam you in the seat then die off. but more of a steady strong pull to redline. you'll loose the lowend but really gain mid to high end. it was very nice, i could only amagne what it would feel like at 18-20 psi with a nice smooth tune.
man it would be a thing of beauty.
Andy
94 L n/a 5spd, Rip
BXSS
Post by BXSS »
+1 on your TD05 assessment, & 18psi feels nice once you get there.
Hope everything is OK with your car.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
92ss satinsvoice
so i cut one of the top bolts off so i could replace it. i didn't have any luck getting the down pipe off be cause one of the lower bolts got stuck so i said F*** it. but i did check for play on the intake side and it was minor.
im going to go around the block to see if the rattling went away.
Andy
94 L n/a 5spd, Rip
94SS_Canada
let us know!
FastRust
92ss satinsvoice
ok, all seems to be well. i tightined down the top bango nut just for luck too.
well so far im at ease, with figers crossed lol.
ill post pic's when my brother wakes up so i can get the camera.
Andy
94 L n/a 5spd, Rip
92ss satinsvoice
ok. so i found out today that my bov is spraying out oil and coolent.
im not sure but i think it might be that fuckin turbo. i was reading on other fourms about people having this problem and they where all reverting the problem back to the turbo's.
anyone have anyother thoughts of what it can be? btw it was cool till i rasied the boost from 11 to 14 at PIR.
Andy
94 L n/a 5spd, Rip
Arctic Assassian
Post by Arctic Assassian »
The td05 I just bought was leaking oil from the rear seal, so when I get my stimulus payment, the turbo's going to deadbolt to be rebuilt. It's odd that it would leak coolant too. When I called deadbolt they said it would be 299 for a full rebuild and balance, plus about 50$ shipping from where I am.
Too bad about your trouble.
Kickin' it old-school.
92ss satinsvoice
thanks for your info :).
i thought that i might of been a head gasket goin but before jumping to conclusions i asked my self what in the inter cooler system has oil and coolent in it, the turbo...
yep, so it looks like im going to have to send it to get rebuilt. and if this dosent fix the problem. engine rebuild time...
Andy
94 L n/a 5spd, Rip
Arctic Assassian
there's coolant in the TB too isnt there? Could that have cracked?
BXSS
Post by BXSS »
Wow that is weird.
You could bypass the coolant to the turbo (a fitting/pipe to join th 2 hoses together) & boost the car to see if it is still spitting out oil & coolant.
If it still is sneezing coolant the problem is not your turbo.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
92ss satinsvoice
well my bov is pre Throtle Body so that wouldnt be a concern unless it was coming out of the exhaust i would think.
thats a good idea about the coolant lines. ill try that idea and see what happens. thanks for the info guys. ill head to the parts store and get a fitting and once again cross my fingers for the best. rather it be the turbo then the motor...
Andy
94 L n/a 5spd, Rip
92ss satinsvoice
before i got to do the coolent thing i checked my oil fill tube for blow by with a card and it was spitting oil out, got my card and hand covered in oil.
yep, motors toast...
:evil:
Andy
94 L n/a 5spd, Rip
scuzzy
Post by scuzzy »
92ss satinsvoice wrote:before i got to do the coolent thing i checked my oil fill tube for blow by with a card and it was spitting oil out, got my card and hand covered in oil.
:evil:
blew some rings eh? gotta be careful running without a tune like that. must resist the urge to get out there and beat on it right after such a mod.
#82 M4 TRSCCA Rallycross
92ss satinsvoice
ya, plus with 155k one the original motor dosen't help ether.
four pulls at PIR. 2 at 11 psi then two at 14psi.
best was a 14.7 @98 with a quick reaction time but slow start because of a weak clutch.
Andy
94 L n/a 5spd, Rip
Post by 555BCTurbo »
If you are going to tune with a PP6...get a wideband...otherwise its like pissing in the dark
BXSS
Post by BXSS »
Here is your opportunity to upgrade....
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
94SS_Canada
REbuild, REbuild!
FastRust
92ss satinsvoice
dont worry guys im not getting rid of the car. wish it happened later and not now because i wanted to pay other things off first. but what ever, its got to be done sooner or later.
time to build a monster... 8)
Andy
94 L n/a 5spd, Rip
