wastegate
the_watts10
wastegate
Post by the_watts10 »
what would make my wastegate be open all of the time and sometimes work like normal
well this is what happened i have had vaccum leaks all over the place from breaking plastic pieces from the turbo swap and it did run to bad until i hooked them back up and now its like my wastegate is open and the turbo wont build pressure would this be from a bad wastegate or from the vaccum routes being wrong?
ej22t hybrid, 3.5" downpipe, Gl turbo intake/desnorkel 9psi DEAD
BXSS
Post by BXSS »
You could test the actuator with compressed air to see if it is opening & closing smoothly.
It may be binding & getting stuck open.
If it is working properly the problem is somewhere else.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
